Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
ASA Phone Proxy issue
I've a CUCM Cluster with 2 nodes which are located in different cities and communicate to eachother through MPLS. some of the phones are on publisher and some of them are on subscriber.
1- I've recently set up phone proxy on cisco ASA. it's working fine for phone ar on publisher but when somone calls to an ip phone on subscriber it rings but can not hear anything.
Just publisher has been published as TFTP on ASA.
2- Extension Mobility and Phone directory service is not working on remote registered phone.
The configuration is as per bellow:
crypto ca trustpoint CUCM_TFTP_SERVER_TP
enrollment self
keypair CUCMTFTP_KP
crl configure
crypto ca trustpoint CAP-RTP-001_TRUSTPOINT
enrollment terminal
crl configure
crypto ca trustpoint CAP-RTP-002_TRUSTPOINT
enrollment terminal
crl configure
crypto ca trustpoint CISCO_MANUFACTURE_CA_TRUSTPOINT
enrollment terminal
crl configure
crypto ca trustpoint CAPF_TRUSTPOINT
enrollment terminal
crl configure
tls-proxy ASATLSP
server trust-point _internal_PP_ASA-CTL
no server authenticate-client
ctl-file ASA-CTL
record-entry cucm-tftp trustpoint CUCM_TFTP_SERVER_TP address x.x.x.x
no shutdown
media-termination MTP
address x.x.x.x
phone-proxy ASA_PHONE_PROXY
tftp-server address 2.2.2.2 interface inside
tls-proxy ASATLSP
cipc security-mode authenticated
ctl-file ASA-CTL
no disable service-settings
timeout secure-phones 0:01:00
proxy-server address 2.2.2.2 interface inside
class-map SEC_SIP
match port tcp eq 5061
class-map SEC_SCCP
match port tcp eq 2443
policy-map VOICE_POLICY
class SEC_SCCP
inspect skinny phone-proxy ASA_PHONE_PROXY
class SEC_SIP
inspect sip phone-proxy ASA_PHONE_PROXY
service-policy VOICE_POLICY interface outside
Hi Karmin
1- I hope to check the following configurtion on page 71 . Can you publisher also subscriber ,Can you do  add for the subcriber
static (inside,outside) 1X.X.X.X  X.X.X.X
http://www.cisco.com/c/en/us/td/docs/security/asa/asa80/configuration/guide/conf_gd/unified_comm.pdf
2- For Extension mobilty , i think HTTPS traffice cannot be established .Please find the below
Cisco ASA:CSCti62447
Please rate all useful information
Re: ASA Phone Proxy issue
Hi islam,
Thanks for reply.
This example is for mixed mode but my cluster is working in non secure mode
       Also, as my subscriber is in another city I can not nat it through my main ASA at publisher site.
195
