05-07-2014 12:04 PM - edited 03-16-2019 10:43 PM
11-13-2015 05:21 AM
Hello Marcel,
I know this questions is from 2014, but I think it could help another one.
Right, the ascom device worked with 12 digits.
Example:
\+4921166612345
\+492116661234
The MAC should be "921166612345" >> SEP921166612345
The MAC should be "492116661234" >> SEP492116661234
Kind regards
Sandra
02-01-2016 02:54 AM
Hi Sandra,
what if the E.164 number is shorter than the 12 digits? I have this at one of my customers, where the E.164 number is 11 digits long and we're using a E.164 dialplan. The devicename must have 12 digits in cucm, i filled the first digit with an E, so the devicename is e.g. SEPE12345678912. But the Devices wont register on cucm. any ideas in how to accomplish a registration here?
03-16-2016 07:32 AM
Hi Mike,
I've tested this for a customer. Please test instead the "E" an "A" like A49123456789 (SEPAA49123456789). I hope this is working for you.
Kind Regards
10-25-2016 06:29 AM
Hi Mike,
it is a bit old, but maybe this helps somebody else:
in the Interoperbility Guide is the MEthod listed for the name of an ASCOM IP-DECT Device:
for E.164 with +:
If the number is longer the 12 digits the first digits will be not used:
+49123456789999 -> SEP123456789999
If the number is 12 or smaller, the + will be convertet to an A and the normal filling Charakter is E
+49123456789 -> A49123456789
+4912345678 -> EA4912345678
In the DECT Master there is an Button called "Register with number" this has to be umarked!!! In the Name Field at the User there hast be inserted the full E.164 with + sign.
Kind regards
