Ask the Expert:Cisco Unified Border Element for PSTN SIP Trunks
ciscomoderator
Community Manager
Community Manager
Read the bioWith Randy Wu
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn from Cisco expert Randy Wu  best practices on how to configure and troubleshoot Cisco UBE for the public switched telephone network Session Initiation Protocol trunks.
Randy Wu is a senior customer support engineer in the Multiservice Voice team at Cisco in Sydney. He has vast experience and knowledge configuring, troubleshooting, and designing Cisco UBE, gateways, and gatekeepers, working with H323, MGCP, and SIP protocols. He joined Cisco as a systems engineer in 1999. He holds CCIE certification (#8550) in Service Provider, Routing, and Switching and Voice.
Remember to use the rating system to let Randy know if you have received an adequate response.
Randy might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the  Collaboration, Voice and Video sub-community discussion forum shortly after the event. This event lasts through June 29, 2012. Visit this forum often to view responses to your questions and the questions of other community members.
85 Replies 85
Hi, Jose
Thanks for your feedback.
Please check the following official Q&A for your questions,
the DRAM does affect the sessions can be supported. To support 800 sessions, 2G DRAM will be recommended.
The performance testing usually will operate at CPU below 75% usage.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps5640/prod_qas09186a00801da69b.html
Q. What are the memory requirements for running the Cisco Unified Border Element?
A. The memory requirements for the Cisco 2800 and 3800 Series platforms  are 128 MB of flash memory and 512 MB of DRAM. For the Cisco AS5350XM  and AS5400XM platforms, 128 MB of flash memory and 1 GB of DRAM are  recommended. For the Cisco 2900 and 3900 Series platforms, 256 MB of  flash memory and 1 GB of DRAM are recommended for traffic loads of fewer  than 500 simultaneous calls. For more than 500 simultaneous calls, or  high calls-per-second (CPS) rates, 2 G of DRAM is recommended.
Q. What are the performance guidelines for the Cisco Unified Border Element?
A. The maximum number of simultaneous IP-to-IP calls that each platform  can carry depends on several parameters, including but not limited to  traffic mix, average call-hold time, call arrival rate, desired CPU  usage percentage, the codec used, transcoding, and whether or not voice  activity detection (VAD) is activated.
The  values in Table 1 assume the use of a G.711 codec, with VAD turned off,  call-hold times of 180 seconds, flow-through mode, Cisco IOS Software  Release 15.0.1M, Ethernet egress, and CPU use not to exceed 75 percent.  These values should be used as guidelines only and should not be taken  as guaranteed performance.
Table 1. Number of IP-to-IP Calls per Platform
Platform
Maximum Number of Simultaneous Calls (Flow-Through)
Cisco 3945E
2500
Cisco 3925E
2100
Cisco 3945
950
Cisco 3925
800
Cisco 2951
500
Cisco 2921
400
Cisco 2911
200
Cisco 2901
100
Cisco ASR 1004; and Cisco ASR 1006 Route Processor 2 (RP2)
5000; 15000*
Cisco ASR 1002, ASR 1004, and ASR 1006 RP1
1750
600
Cisco 3845
500
Cisco 3825
400
Cisco 2851
225
Cisco 2821
200
Cisco 2811
110
Cisco 2801
55
*Note: Up to 5000 calls are supported on Cisco IOS Software Release 2.5, and up to 15000 calls on Release 2.6 or later.
Rgds/Randy
Hello Randy,
Indeed the Q&A clarified most of my questions, and at the moment i have only one point that i would like you to clarify.
The point is regarding the impact of MTP Software co-located with the CUBE.
Can provide me some feedback on this topic?
Jose
Hi, Jose
Regarding to the impact of software MTP co-located with the CUBE, there is no public data that I can give it out, sorry about that.
Please consult your local System Engineer for the platform you will deploy in your future design, basically it will support less connection compared to the information announced in the Q&A URL.
Rgds/Randy
j.huizinga
Level 6
Level 6
Hello Randy,
I am implementing a CUBE device on a 3845.
I have a question avbout the MTP for SIP early offer:
Is it possible to let callmanager do a SIP delay offer (no MTP) and the CUBE do an early offer to the provider?
Would this eliminate the MTP configuration?
Jan
Hi,  Jan
Thanks for your question.
Your setup is possible,  under the "voice service voip" -> "sip" configuration, there is one command "early-offer forced", once you configure this, CUBE will send the codec configured under the outgoing dial-peer pointing to the provider as the SDP information even it is delay offer call from CUCM.
This command can also be configured under the dial-peer, the command will be "voice-class sip early-offer forced", which will only take effect when  the call hits this dial-peer while the previous command under "voice service voip" will have global effect.
Rgds/Randy
Marek Janecek
Hi Randy,
we tried to set up basic SRTP-RTP topology on CUBE using this guide (CUBE Support for SRTP-RTP Internetworking) which was the only comprehensive up-to-date guide how to configure it I was able to find.
We hadn't CME license on that CUBE at the time (which is needed because transcoders have to register via SCCP), so we used "associate application cube" under dspfarm profile and it seems to work flawlessly and without that SCCP mess. Is there any problem with this solution or reason why it's not described anywhere ?
Obviously the SCCP version (with transcoders registering to CME at CUBE) have to be used if DSP resources are in other box than CUBE but is there any other drawback ?
topology:
CUCM----(Secure SIP trunk)----CUBE----(SIP trunk)----ISP
Marek
Hi, Marek
It looks like you are one of our more advanced users of CUBE, this feature was introduced recently.  You already described the advantage of this mode which will not require any CME related configuration and SCCP configuration, the SCCP controlled transcoder was replaced by Cisco internal control , and obviously without SCCP command, it can only be used locally, and it can only be supported by later IOS version with PVDM3 modules.
I can only find the following information from CCO which is for IOS-XE version of ASR1k in enterprise mode CUBE which will have the similar feature of ISR G2 as CUBE.
http://www.cisco.com/en/US/partner/docs/ios-xml/ios/voice/cube_proto/configuration/xe-3s/voi-dspbased-func.html
I will contact with the product marketing team to reflect the CCO information about this new feature, thanks.
Rgds/Randy
Ayodeji Okanlawon
Hi Randy..
I just want some clarification on ringback issues with SIP trunks. According to cisco documentation it says:
By default, Cisco Unified Communications Manager  will signal the calling phone to play local ringback if SDP is not  received in the 180 or 183 response. If SDP is included in the 180 or  183 response, instead of playing ringback locally, Cisco Unified  Communications Manager will connect media, and the calling phone will  play whatever the called device is sending (such as ringback or busy  signal).
This then suggests that If you do not receive ringback, the device to which you are  connecting may be including SDP in the 180/183 response, but it is not  sending any media before the 200OK response.
Now in cases like this, as I have one case I am troubleshooting now, I tried to use the disable early media to force cucm to play ringback locally. But it didnt work.
Also according to cisco documentation
disable-early-media 180
To specify which call treatment, early media or local ringback, is provided for 180 responses with 180
responses with Session Description Protocol (SDP), use the disable-early-media 180 command in
sip-ua configuration mode. To enable early media cut-through for 180 messages with SDP, use the no
form of this command. disable-early-media 180
config t
sip-ua
disable-early-media 180.
Can you please clarify how ringback should work over sip trunk especially in a case when the ITSP is sending 183 with SDP. If in this scenario we do not get ring back from the ITSP is there a way to force CUCM to play ringback locally.
Can the same be done for CCME too?
Please rate all useful posts
Hi, Aokanlawon
Thanks for your questions.
1.  If ITSP sends 183 with SDP, ITSP has the responsibility to play the ringback or any audio, for the CUBE or CUCM, there is only one thing to do which is to cut through media,  by theory, the device along the way should not change it from 183 with SDP to 180 which will change the behavior and might cause further issue.
2. The command you mentioned will not help your scenario.
3. The root cause of the issue is from ITSP, it should not send 183 with SDP while not provide ringback tone.
4. If you really want to change the behavior, you can use Lua script in CUCM version later than 8.5(1)  to change the 183 message to 180, which might force the CUCM to play the local ringback. The feature in CUCM called SIP transparency and normalization.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmcfg/b06scrpt.html
Rgds/Randy
Randy as always thank you for the detailed explanation.
I guess this willbe taking back to the ITSP then. The only other thing is that when call is made towards the ITSP you can hear the called phone ringing but the cisco phone does not ring. Does this not suggest that the ITSP is playing ringback?
Secondly, then is the disable-early media 180 applicable? When can this be used?
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Hi, Aokanlawon
1.  in the scenario you described, the called phone ringing is different than the calling party hearing the ringback, if you saw the 183 with SDP passing through from CUBE to the CUCM and if CUCM use early offer to setup this call, and you still can't hear the ringback tone from ITSP, it will be ITSP issue, but  if the CUCM use delay offer to setup the call, it will be another story, you have to use rel1xx to cut through the ringback tone from ITSP to CUCM via CUBE.
2. the "disable-early media 180" can only affect 180 message with SDP.
Rgds/Randy
Randy, Excellent thoughts from you. Thank you so much for clarifying this..
If this is CCME ( I know ccme does early offer by default) Can you use rel1xxx to cut through the ringback tone from ITSP?
Hi, Jose
If it is CCME, since it use early offer, will not have the issue while you have CUCM , the rel1xx is a compensation for CUCM delay offer.
Rgds/Randy
Gordon Ross
Level 9
Level 9
Why are the debug messages for voice so hard to understand, compared to, say traditional IP debug outputs ? I *really* struggle piecing together what CUBE is doing.
GTG
Please rate all helpful posts.
Hi, Gordon
If you refer to "debug ccsip message", it is kind of readable, isn't it?
Rgsd/Randy
