assign a private line to n IP phone
Dears, is there anyway that i can use on callManager 4.3 to assign a private line to a specific extension so that extension only can dial outside numbers through this line?
There is any similar way to configure it on cme by associating a directory number with a foreign exchange office (FXO) port. Is there any similar way to configure it on callmanager 4.3?
1 ACCEPTED SOLUTION
Re: assign a private line to n IP phone
no, you can create a route pattern and bind it to the FXO. but there is no real equivalent of 1 button - 1 fxo
on FXO config attendant DN to that line
java
if this helps, please rate
java
www.cisco.com/go/pdi
very simple, use a CSS that only reaches route patterns to PSTN
if you don't want anyone calling the line create a special partition and do not add it to any CSS
java
java
there is no config similar to the trunk that is configured on cme that associates the dn with the fxo port?
java
java
286
