Assigning analog ext's to pick group in CME
Hi, all. We're running CME 7.1 at a site where a couple of analog extensions are defined in the gateway since they are connected to an FXS card. Since it's a small office, all extensions on 7975 devices are in a single pick group.
I have not been able to discover a way of assigning this pick group to the analog extensions in the IOS. Is this possible?
If not, will it cause a conflict if I define them in CME, perhaps as park-slot extensions, so I can make the p/g assignment?
Or is there another work-around?
Thanks much! Steve
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Assigning analog ext's to pick group in CME
Configure the FXS ports in SCCP mode (refer to admin guide), you will be able to handle them as ephone and use all features.
Please remember to rate useful posts with the scrollbox below.
Thanks much!
133
