Community Member
Assigning authorization code to a directory number
I have a challenge and i will like your assistance.
I have been aske to assign the individual force authorization code to the users' directory number, how possible is it? If possible how can it be done. I have a the CUCM version 7.1.5.....
Thanks and regards
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Assigning authorization code to a directory number
FACs are forced on route patterns and not DNs. FACs are the build individually and not assigned to specific user and anyone who knows them can use them. What is the purpose for assigning them to DNs?
Community Member
Dear Chris,
Thanks for your response.
The purpose is to achieve an optimum level of security (sharing, compromise), ensuring that FACs are not useable on any other DN/Deskphone except that which it is assgned.
Not natively, you might need to look at 3rd parties.
Chris
87
