Community Member
Assistance with Call Manager 6.1 and 3845 gateway
We currently have a PRI link to our gateway which sends calls to call manager 6.1. We want to add two more basic rate ISDN connection to the same gateway with different number rages. meaning we will have three different number ranges connecting to the same gateway and call manager. is this possible?
How do we go about this?
my idea is to plug in the ISDN basic rate module 2BRI-NT/TE to the 3845 gateway and plug in the ISDN NTs, then configure voice peers with the call manager as the session target.  then create phone profiles on Call manager with this new numbers (exension mobility is not required for this)
please help.
Regar
1 ACCEPTED SOLUTION
Community Member
Re: Assistance with Call Manager 6.1 and 3845 gateway
try my previous answer... this worked for me
jatin
Community Member
hi Rager,
yup you can connects multiple bri cards and it works fine .. we are also using the same in our enviorment .. infact we are doin this for 7 clients .. means 7 different lines are connected to the same gateway and they make their calls from their own phones infact some phones are sharing 2 lines with different lines.. this is just add gateways and give proper CSS and partitions.. if you need help feel free to write..
if you like this then plz rate this also
Reger,
make sure to verify that there are sufficient DSP resources on the gateway. use the DSP calculator, http://cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl, and compare the results with what is currently installed on the router.
-Felipe
Community Member
the phone rings once and then cut. i don't see any errors when I do debug q931.
please assist.
here are my configs
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
isdn sending-complete
dial-peer voice 30 voip
destination-pattern 1192
session target ipv4:192.168.9.20
incoming called-number .T
codec g711ulaw
no vad
also added the BRI interface on gateway configuration of the call manager and shows registered.
Community Member
hi there which IOS you are having ..becoz i was facing the same problem with my cucm 6.1
& 3825 gateway ... and the end of the dayit was a bug in IOS, spent 2 days, its not mentioned anywhere,
we had 3825adventprise srv ios still we got this issue, and then i changed the ios
to spservices & everything went fine.......
please rate if usefull
jatin
Community Member
Cisco IOS Software, 3800 Software (C3845-ENTSERVICESK9-M), Version 12.4(17a)
Community Member
jatin
Community Member
I changed to
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(3i), R
still the same problem. debug gives the following message "Voice call setup failed-Incoming-Outgoing call collision"
The phone rings once and drop
Community Member
hi there ..
see i am using the same setup .. and when i faced this i implemented the same.. second this why u have a dial peer in router conf .. i dont have anythng like that,, any specific reason.. if possible share full conf of router and gateway on cucm 6.1
can you collect the following command output.
show version
show run
show isdn status
show voice dsp detail
show voice dsp group all
show dial-peer voice summary
show voice call summary
show voice port summary
show ccm-manager
show mgcp
Enable the following debugs and make a test call.
debug mgcp packet
debug isdn q931
debug voip ccapi inout
Please note the calling and called party numbers.
-Felipe
Community Member
Output attached.
Community Member
it was the the IOS bug issue. I upgraded to Version 12.4(24)T4 and it works perfect.
Thanks.
648
