03-18-2008 08:13 AM - edited 03-15-2019 09:31 AM
i want to create a single dial peer that will include all these extensions
3200
3201
3202
3203
3204
3205
3206
3207
3208
3209
3210
3211
3213
3214
3215
3216
3217
will this work
destination-pattern 32[0-9]1[1-7]
Solved! Go to Solution.
03-18-2008 08:47 AM
Yours works fine, if you want You can even narrow down 3rd digit
32[0-2][1-7]
03-18-2008 08:47 AM
32[0-2][1-7]
03-18-2008 08:50 AM
cool thanks
03-18-2008 08:53 AM
well it has to match four digit but i just realized that
it wont grab the 3210
32[0-9]1[0-7]
03-19-2008 08:13 AM
obviously, you are capturing more than what you list. if that is OK....then you are good.
03-19-2008 08:40 AM
So wouldn't this work better?
32[0-9][0-7]
03-19-2008 08:41 AM
I meant:
32[0-2][0-7]
Sorry for multiple posts!
