assitance with dial peer
ggittins
i want to create a single dial peer that will include all these extensions
3200
3201
3202
3203
3204
3205
3206
3207
3208
3209
3210
3211
3213
3214
3215
3216
3217
will this work
destination-pattern 32[0-9]1[1-7]
Rajesh Revuru
Level 4
Level 4
Yours works fine, if you want You can even narrow down 3rd digit
32[0-2][1-7]
6 Replies 6
Rajesh Revuru
Level 4
Level 4
32[0-2][1-7]
cool thanks
well it has to match four digit but i just realized that
it wont grab the 3210
32[0-9]1[0-7]
obviously, you are capturing more than what you list. if that is OK....then you are good.
Steve
Please rate all helpful posts.
So wouldn't this work better?
32[0-9][0-7]
I meant:
32[0-2][0-7]
Sorry for multiple posts!
