Association of DSPFARM
I configured successfully meet-me service on CCME 4.1, but I have a doubt on the correct association of the profile for transcoding cause the status is ASSOCIATION IN PROGRESS, what could be missing??
2821#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 2, Service = TRANSCODING, Resource ID = 2
Profile Description :
Profile Admin State : UP
Profile Operation State : RESOURCE ALLOCATED
Application : SCCP Status : ASSOCIATION IN PROGRESS
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 2
Number of Resource Available : 2
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 1 9.4.5 UP N/A FREE xcode 2 - - -
0 5 9.4.5 UP N/A FREE xcode 2 - - -
0 6 1.1.137 UP N/A FREE conf 1 - - -
0 9 1.1.137 UP 1 USED conf 1 7798 32071 12709
0 9 1.1.137 UP 1 USED conf 1 7804 27321 27311
Total number of DSPFARM DSP channel(s) 4
Thanks for your help.
Juan Carlos
Re: Association of DSPFARM
Juan,
sccp ccm group 22
bind interface GigabitEthernet0/0.30
associate ccm 7 priority 1
associate profile 1 register confdsp1
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
I don't see that the transcoding profile has been associate at all!
HTH,
Chad
Hi Chad,
That's exactly my problem and my doubt, could you kindly give your comments on how to associate transcoding profile.
I appreciate for your answer.
Juan Carlos
I test it with this command and it's the same:
sccp ccm group 22
associate profile 2 register mtp001de5e1d5f8
Kindly please give me your comments.
Juan Carlos
did you add mtp001de5e1d5f8 as a transcoding resource unfer CCM? Check registration status on the CCM and see if it shows registered then..
HTH,
Chad
Well Chad, I just remember you that I'm running CCME, I will refresh my configuration only for the dsp if this could help to see the problem:
sccp local GigabitEthernet0/0.30
sccp ccm 172.16.0.1 identifier 7 version 4.1
sccp
sccp ccm group 22
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
telephony-service
sdspfarm conference mute-on 845 mute-off 845
sdspfarm units 2
sdspfarm transcode sessions 2
sdspfarm tag 1 mtp0014f2018ad0
sdspfarm tag 2 confdsp1
conference hardware
Juan Carlos
Chad, now I got it and both are associated, I had the ID tag interchanged on SCCP group and telephony-service, on this last post I realized that.
Thanks anyway for your time.
Juan Carlos
916
