asterisk integrate with cisco vg
Hi ;
i encounter some tehnical issue with asterisk pbx integrate with cisco VG C3825. I did configure VG as H323, look fine. but encounter ringback tome issue where by pstn user call in to IP phone has no ringback tone. Pls find main vg config as per below ;
voice service voip
allow-connections sip to sip
h323
  no call service stop
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
  call preserve
voice-port 0/1/0
compand-type a-law
cptone MY
voice-port 0/1/1
compand-type a-law
cptone MY
dial-peer voice 10 pots
incoming called-number .
direct-inward-dial
port 0/1/0
forward-digits all
dial-peer voice 100 voip
tone ringback alert-no-PI
description ***Dial-peer_for_Subscriber01***
preference 1
destination-pattern 6204....
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
voice-class codec 1
voice-class h323 1
session target ipv4:10.200.214.10
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 101 voip
description ***Dial-peer_for_Publisher***
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.200.214.11
no vad
dial-peer voice 1002 pots
description ***Dial-peer_for_MobileCall***
destination-pattern 901........
port 0/1/0
forward-digits 10
But when i used to same config revert back to CCM with cisco VG it work fine. Pls advice for VG and asterisk PBX config. Thanks.
rgds
tan peng ong
Everyone's tags (1)
357
