ATA 168 from V
I have as ATA 168. It is from V+++. Sw ver V3.2.0
I have the DCHP url   from VIR. It appears  not to be password locked.
I enter it in the browser  it says not found.
I cannot look at the config menu.
I tried 3 browsers - even turned off the FW.
Has to be something simple?
Any advice? I have read all the ATA 186 posts
Re: ATA 168 from V
Assuming u mean ATA186.
Can u ping ATA's IP (as learnt from IVR menu?) from the PC you are trying to http to ?
Please see following doc and try assigning it a static IP via IVR menu preferably on the
same subnet as the PC you have and try http again:
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_configuration_example09186a00800c3a50.shtml
HTH,
DK
Re: ATA 168 from V
Sorry about the model number  - yes 186 ATA
Yes can ping the url.
Will give the IVR static IP assign
Re: ATA 168 from V
OK it appears it  password locked. I cannot change the IP adr.
Tried the password reset no luck.
Guess I cannot use this for another VOIP service.
I will read more about the password rest, but I think I am at a  loss.
Looks like V has won one
Re: ATA 168 from V
Password research follow-up . Appears   from  what I read and what I have tried to program, I cannot use this ATA on any other VOIP network.. NO way to reset the password or the config
Re: ATA 168 from V
Tried factory reset ?
http://www.cisco.com/en/US/docs/voice_ip_comm/cata/186_188/2_15/english/administration/guide/sip/SIP88CH3.html#wp1089746
Step 1 Press  the function button on the Cisco ATA.
Step 2 Press  the digits 322873738 (FACTRESET)  then press # on your  telephone keypad.
Step 3 Press  3 on  your telephone keypad to confirm that you want to reset the Cisco ATA, then hang  up the phone.
Re: ATA 168 from V
Yes did that. It keeps asking for the password.. nope it is locked by V. I will try to contact them for the password. I closed the acct years ago. I want to try another VOIP  service  - cheaper  but do not want to invest in another ATA
271
