ata 186 14400
Anyone able to get an ATA to run at 14400?
thx as always
Super Bronze
Re: ata 186 14400
General tips:
1) Disable ECM and any high-speed/fancy features you can on the fax front panel itself
2) Ensure your E1s have no clock slips using 'sh controllers e1'
3) Ensure you have a 100% QoS setup with as little packet loss as possible
4) Be happy if your faxes work.. the above tend to improve reliability but slower speeds are typical on ATAs in my experience.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Re: ata 186 14400
Can you explain your topology in more detail?  What protocol are you running on the ATA?  What VoIP protocol is your PSTN gateway running?  And What is the PSTN connection?  Is the PSTN connection an IP SIP trunk?
157
