ATA 186 Factory reset protection
How to configure OpFlags bits 28-31 with a value of 6 via IVR?
Re: ATA 186 Factory reset protection
Disconnect the ethernet cable. Plug phone to phone1 jack.
Step 1 Lift the handset and press the Function button located on top of the Cisco ATA 186.
Step 2 Enter the IVR menu number for the parameter that you want to configure or the
command that you want to execute; then, press the pound key(#).
IStep 3 Follow the applicable prompts.
Step 4 When you have finished, make sure you press 3 to save your changes.
Step 5 Hang up the telephone. The Cisco ATA 186 resets.he function button will fast-blink when the
reset is complete.
reboot (sometimes required)
http://www.cisco.com/univercd/cc/td/doc/product/voice/ata/atarn/atarn16.htm#89135
Thank you but the question is not how to use the IVR.
The question is HOW TO CONFIGURE OpFlags BITS 28-31 WITH A VALUE OF 6 VIA IVR?
check the ATA admin guide.
i did not do it personally but it is the voice menu "323"
632
