01-24-2012 01:02 PM - edited 03-16-2019 09:11 AM
I have to add an analog phone to one of our remotes sites and I want to use an ATA 186 that we already own. Do the ATA 186 use a load file like a phone does? Ive seen some simple documentation that states you set it up like a phone? Thanks
01-24-2012 01:44 PM
Yes, you should have SCCP firmware on the ATA.
It will then basically behave like an IP phone.
The documentation is the normal CME and ATA one.
01-27-2012 07:24 AM
thanks, do I have to make sure a certain "load file" is in flash and available? If so, what file? We have plenty of 7960 and 7961 that work fine already. thanks
01-27-2012 08:00 AM
Look at this link
Alex
