ATA 186, SCCP - It can't established TCP connection
Hi all!
I try to deploy ATA 186 via routed ip link. ATA uses SCCP image and should be registered on CME 4.1.
ATA 186 obtains IP info (and TFTP address) via DHCP. It successfully downloads all necessary configs.
.Aug 2 16:29:13.646: TFTP: Looking for ATA001B54849547.cnf.xml
.Aug 2 16:29:13.646: TFTP: Opened system:/its/ATADefault.cnf.xml, fd 1, size 336 for process 126
.Aug 2 16:29:13.686: TFTP: Finished system:/its/ATADefault.cnf.xml, time 00:00:00 for process 126
.Aug 2 16:29:13.694: TFTP: Looking for ata001b54849547
.Aug 2 16:29:13.718: TFTP: Looking for atadefault.cfg
.Aug 2 16:29:13.730: TFTP: Opened flash:atadefault.cfg, fd 1, size 430 for process 126
.Aug 2 16:29:13.766: TFTP: Finished flash:atadefault.cfg, time 00:00:00 for process 126
.Aug 2 16:29:13.774: TFTP: Looking for United_States/7960-tones.xml
.Aug 2 16:29:13.774: TFTP: Opened system:/its/united_states/7960-tones.xml, fd 1, size 903 for process 126
.Aug 2 16:29:13.858: TFTP: Finished system:/its/united_states/7960-tones.xml, time 00:00:00 for process 126
.Aug 2 16:29:14.650: TFTP: Looking for ATA1B5484954701.cnf.xml
.Aug 2 16:29:14.650: TFTP: Opened system:/its/ATADefault.cnf.xml, fd 1, size 336 for process 126
.Aug 2 16:29:14.690: TFTP: Finished system:/its/ATADefault.cnf.xml, time 00:00:00 for process 126
.Aug 2 16:29:14.698: TFTP: Looking for United_States/7960-tones.xml
.Aug 2 16:29:14.698: TFTP: Opened system:/its/united_states/7960-tones.xml, fd 1, size 903 for process 126
.Aug 2 16:29:14.778: TFTP: Finished system:/its/united_states/7960-tones.xml, time 00:00:00 for process 126
But when it tries to to register with CME using SCCP it cannot established TCP connection:
Aug 2 16:26:25.370: IP: s=10.90.110.74 (Vlan2), d=10.90.103.1 (Tunnel0), g=192.168.1.1, len 44, forward
Aug 2 16:26:25.370: TCP src=14902, dst=2000, seq=119758848, ack=119758848, win=16000 SYN
Aug 2 16:26:26.450: IP: tableid=0, s=10.90.110.74 (Vlan2), d=10.90.103.1 (Tunnel0), routed via RIB
Aug 2 16:26:26.450: IP: s=10.90.110.74 (Vlan2), d=10.90.103.1 (Tunnel0), g=192.168.1.1, len 44, forward
Aug 2 16:26:26.450: TCP src=14810, dst=2000, seq=119382016, ack=119382016, win=16000 SYN
Aug 2 16:26:27.370: IP: tableid=0, s=10.90.110.74 (Vlan2), d=10.90.103.1 (Tunnel0), routed via RIB
Aug 2 16:26:27.370: IP: s=10.90.110.74 (Vlan2), d=10.90.103.1 (Tunnel0), g=192.168.1.1, len 44, forward
Aug 2 16:26:27.370: TCP src=14902, dst=2000, seq=119758848, ack=119758848, win=16000 SYN
Aug 2 16:26:30.454: IP: tableid=0, s=10.90.110.74 (Vlan2), d=10.90.103.1 (Tunnel0), routed via RIB
Aug 2 16:26:30.454: IP: s=10.90.110.74 (Vlan2), d=10.90.103.1 (Tunnel0), g=192.168.1.1, len 44, forward
Aug 2 16:26:30.454: TCP src=14810, dst=2000, seq=119382016, ack=119382016, win=16000 SYN
Aug 2 16:26:31.374: IP: tableid=0, s=10.90.110.74 (Vlan2), d=10.90.103.1 (Tunnel0), routed via RIB
There is no any filters on the path from ATA to CME. Also i connected PC with the same IP and made telnet CME_IP_Address 2000 and connection was successfully established. But it can't established from ATA. Could you help me with this problem.
Thank you in any help
Arseny
254
