Community Member
ATA 187 and CUCM 6
Hi All,
One of the guys at work has been trying and complete the following tasks, but so far no luck.  Wondering if anyone has been able to get this to work..
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_configuration_example09186a0080b3b136.shtml
Cheers
Jason
Community Member
ATA 187 and CUCM 6
Please explain what the problem exactly.
Community Member
ATA 187 and CUCM 6
Im told that the process doesnt work.
I will look into it further if I get confirmation that someone else has been able to follow the procedure and get it to work, other wise I will look for another solution using CUCM 6 and analogue ports.
Cheers
Jason
Green
ATA 187 and CUCM 6
Jason,
According to the data sheet for ATA 187
http://www.andovercg.com/datasheets/cisco-ata-187-analog-telephone-adaptors.pdf
Cisco UCM Version Compatibility
Cisco UCM Versions 7.1.5, 8.0.2, or higher
No support for CUCM 6
Alex
Regards, Alex. Please rate useful posts.
Community Member
ATA 187 and CUCM 6
Hi Alex,
Agree, but was hoping that since the tech note specifically says CUCM 6 and an ATA 187, there may have been a workaround to get the ATA187 to use SCCP rather than SIP.
Jason
Green
Re: ATA 187 and CUCM 6
Jason
I have just checked the software down load pages.
2 Versions for ATA187
9.0.3
9.2.1
Both SIP and state you need at least CUCM 7.1.5
Looking at the number of posts for ATAT 187 issues iyt
may be better to stick with ATA 186 & 188 or the VG200 series for
a while yet.
Alex
Hello Jason ATA 187 is not compatble with CUCM 6.X, there is no otherway.
Leonardo Santana
Community Member
ATA 187 and CUCM 6
Just this month, it looks like a new firmware has been released for the ATA187. Unfortunately all I can download from Cisco right now is the release notes. The firmware is not posted yet for download. In the release notes it says it will support Call Manager 6.15. We are at 6.14 so I am hoping that it should still work. It also states in the release notes that it has fixed the T38 faxing issues. I am anxious to try this out in the lab.
Community Member
763
