ATA 187 and Konica 2900/3900 Fax Issues
We have Konica 2900/3900 fax machines and we are unable to receive faxes.  We are able to send out faxes. The fax machine is connected to an ATA 187.  We use MGCP on our voice router and the calls come in on the serial interface T1 (PRI) line.
CUCM version: 8.5.1.10000-26
I can see the calls come in on the voice router (gateway) and when an analog phone is connected it works fine.  Seems like the destination fax machine (the one connected to the ATA) answers when i call but the transmission does not complete and a "NG" error is printed out on the source fax machine.
Here is my config:
***** show run *****
boot-start-marker
boot system flash0 c2951-universalk9-mz.SPA.151-3.T.bin
boot-end-marker
card type t1 0 0
logging snmp-authfail
no logging queue-limit
logging buffered 30000
no logging rate-limit
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
no ipv6 cef
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name xxxxxxxxxxxxxxxxxxxxxxxx.com
isdn switch-type primary-ni
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
no fax-relay sg3-to-g3
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice iec syslog
hw-module pvdm 0/0
archive
log config
  hidekeys
redundancy
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24 service mgcp
description XO CID: XO xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
controller T1 0/0/1
description XO CID: XO xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ip tcp path-mtu-discovery
interface GigabitEthernet0/0
description **Connection to xxxxxxxxxxxxxxxxxxxxxxx**
ip address x.x.x.x
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
description XO xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:23
description XO xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 x.x.x.x
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/0/0:23
echo-cancel coverage 64
voice-port 0/0/1:23
ccm-manager fallback-mgcp
ccm-manager redundant-host x.x.x.x x.x.x.x
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm x.x.x.x identifier 2 version 7.0
sccp ccm x.x.x.x identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 2 register XXXXXXXXXXXXXXXX
associate profile 1 register XXXXXXXXXXXXXXXX
dspfarm profile 1 transcode
description TRANSCODER
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 25
associate application SCCP
dspfarm profile 2 conference
description Conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 20
dial-peer voice 911 pots
destination-pattern 911
direct-inward-dial
port 0/0/0:23
forward-digits 5
dial-peer voice 9911 pots
destination-pattern 9911
direct-inward-dial
port 0/0/0:23
forward-digits 5
dial-peer voice 929 pots
destination-pattern 9[2-9]..[2-9]......
direct-inward-dial
port 0/0/0:23
dial-peer voice 9129 pots
destination-pattern 91[2-9]..[2-9]......
direct-inward-dial
port 0/0/0:23
prefix 1
dial-peer voice 9011 pots
destination-pattern 9011T
direct-inward-dial
port 0/0/0:23
prefix 011
gatekeeper
shutdown
call-manager-fallback
max-conferences 30 gain -6
transfer-system full-blind
ip source-address x.x.x.x port 2000 strict-match
max-ephones 250
max-dn 500
***** show ver *****
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.1(3)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 15-Nov-10 23:12 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
CB-VA01-GWL004 uptime is 30 weeks, 1 hour, 11 minutes
System restarted at 14:08:02 EDT Thu May 5 2011
System image file is "flash0:c2951-universalk9-mz.SPA.151-3.T.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 483328K/40960K bytes of memory.
Processor board ID FTX1509AJ21
3 Gigabit Ethernet interfaces
48 Serial interfaces
2 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#            PID                              SN
*0              CISCO2951/K9          FTX1509AJ21
Technology Package License Information for Module:'c2951'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
uc            uck9          Permanent     uck9
data          None          None          None
What is the best way to troubleshoot this?
Kamil
Everyone's tags (4)
1 REPLY
the only PRIs on this gateway are MGCP not H.323.  Therefore, you need to enable T.38 in the MGCP configuration.
no mgcp fax t38 inhibit
no mgcp
mgcp
1475
