ATA 187 does not registrer Call Manager Express release 9.1
Hi, guys!
My name is Karina and I really would like some advices from the expects, cose I did almost everything that I could to fix that problem.
I configured an ATA 187 on the customer's CME, when I access the ATA by IVR I can take the IP from the DCHP (DHCP Server is running on CME, it is working because the others phones are working good).
However when I insert the IP by Web Site I can see the ATA got the IP and all configuration but the message via web it is still registering.
By CME I didn't find its from show ephone registered. The CNF file was created and I didn't see the IP Address that I got from IVR.
I tried to configured this device such as SCCP and SIP.
The actual firmware is APP 187.9-0-3-1 in the CME is: APP 187.9-2-3-1
Tks so much.
Read the following thread it should solve your issue:
https://supportforums.cisco.com/thread/2190400
Voice CCIE #37771
Tks Hermanus but before I post this message I saw it I did the same but I didn´t get the same result, unfortunately.
I looked all forum the closed answer it was the link that you sent me.
I´ll see the documentation again.
Re: ATA 187 does not registrer Call Manager Express release 9.1
can you share your config with me please?
Here is another thread:
https://supportforums.cisco.com/message/3659818#3659818
https://supportforums.cisco.com/message/3822838#3822838
Voice CCIE #37771
I just took off some informations about the client´s routers but the informations that you need is here:
Tks for the new links I´ll see them.
CME-X#show run
Building configuration...
Current configuration : 43530 bytes
! Last configuration change at 12:52:58 UTC Thu Jan 16 2014
! NVRAM config last updated at 21:18:31 UTC Wed Jan 15 2014
version 15.2
hostname CME-X
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
enable password cisco
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
ip cef
ip dhcp excluded-address 10.93.4.0 10.93.4.100
ip dhcp pool TelefoniaIP
network 10.93.4.0 255.255.255.0
default-router 10.93.4.1
  option 150 ip 10.93.4.10
no ip domain lookup
no ipv6 cef
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
sip
  registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice register global
mode cme
source-address 10.93.4.10 port 5060
max-dn 10
max-pool 20
load 9971 sip9971.9-4-1-9.loads
load ATA-187 ATA187.9-2-3-1.loads
authenticate register
authenticate realm all
timezone 17
create profile sync 0003006607027217
camera
video
voice register dn  1
number 5514
allow watch
name Carla
label Carla
voice register dn  2
number 5533
allow watch
name Fax 2
label Fax 2
voice register dn  3
number 5533
allow watch
name Fax 1
label Fax 1
voice register pool  1
id mac 64E9.502E.FEA7
type 9971
number 1 dn 1
username 12345 password 12345
codec g711ulaw
voice register pool  2
ata-ivr-pwd 1234
id mac 0C68.0360.21FB
type ATA-187
number 1 dn 2
number 2 dn 3
username cisco password cisco
voice translation-rule 1
rule 1 /^0015/ /0/
voice translation-rule 2
rule 2 /^00/ /0021/
voice translation-profile Incluir_DDD
translate called 2
hw-module pvdm 0/0
hw-module sm 1
redundancy
controller E1 0/0/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
  country brazil
  metering
  debounce-time 10
  answer-signal group-b 1
controller E1 0/0/1
framing NO-CRC4
ds0-group 0 timeslots 1-5 type r2-digital r2-compelled ani
cas-custom 0
  country brazil
  metering
  debounce-time 10
interface Loopback0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.114
encapsulation dot1Q 114
ip address 10.93.4.10 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.93.4.10
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface SM1/0
ip unnumbered GigabitEthernet0/0.114
service-module ip address 10.93.4.11 255.255.255.0
!Application: CUE Running on SM
service-module ip default-gateway 10.93.4.1
interface SM1/1
description Internal switch interface connected to Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.93.4.1
ip route 10.93.4.11 255.255.255.255 SM1/0
tftp-server flash:/Phones/6901/APP6901SCCP.9-3-1-SR1-3.zz.sgn
tftp-server flash:/Phones/6901/APP6911SCCP.9-3-1-SR1-3.zz.sgn
tftp-server flash:/Phones/6901/BFS6911SCCP.9-3-1-SR1-3.zz.sgn
tftp-server flash:/Phones/6901/KNL6901SCCP.9-3-1-SR1-3.zz.sgn
tftp-server flash:/Phones/6901/KNL6911SCCP.9-3-1-SR1-3.zz.sgn
tftp-server flash:/Phones/6901/SCCP6901.9-3-1-SR1-3.loads
tftp-server flash:/Phones/6921/DSP69xx.12-4-122-02-121029.zz.sgn
tftp-server flash:/Phones/6921/SCCP69xx.9-4-1-3.loads
tftp-server flash:/Phones/6921/SCCP69xx.9-4-1-3.zz.sgn
tftp-server flash:/Phones/7915/B015-1-0-4-2.SBN
tftp-server flash:/Phones/7937/apps37sccp.1-4-5-7.bin
tftp-server flash:/Phones/7942/apps42.9-3-1ES13.sbn
tftp-server flash:/Phones/7942/cnu42.9-3-1ES13.sbn
tftp-server flash:/Phones/7942/cvm42sccp.9-3-1ES13.sbn
tftp-server flash:/Phones/7942/dsp42.9-3-1ES13.sbn
tftp-server flash:/Phones/7942/jar42sccp.9-3-1ES13.sbn
tftp-server flash:/Phones/7942/SCCP42.9-3-1SR2-1S.loads
tftp-server flash:/Phones/7942/term42.default.loads
tftp-server flash:/Phones/7942/term62.default.loads
tftp-server flash:/Phones/9971/dkern9971.100609R2-9-4-1-9.sebn
tftp-server flash:/Phones/9971/kern9971.9-4-1-9.sebn
tftp-server flash:/Phones/9971/rootfs9971.9-4-1-9.sebn
tftp-server flash:/Phones/9971/sboot9971.031610R1-9-4-1-9.sebn
tftp-server flash:/Phones/9971/sip9971.9-4-1-9.loads
tftp-server flash:/Phones/9971/skern9971.022809R2-9-4-1-9.sebn
tftp-server flash:music-on-hold.au
tftp-server flash:dkern9971.100609R2-9-4-1-9.sebn
tftp-server flash:kern9971.9-4-1-9.sebn
tftp-server flash:rootfs9971.9-4-1-9.sebn
tftp-server flash:sboot9971.031610R1-9-4-1-9.sebn
tftp-server flash:sip9971.9-4-1-9.loads
tftp-server flash:skern9971.022809R2-9-4-1-9.sebn
tftp-server flash:/GUI
tftp-server flash:/GUI/admin_user.html
tftp-server flash:/GUI/admin_user.js
tftp-server flash:/GUI/CiscoLogo.gif
tftp-server flash:/GUI/Delete.gif
tftp-server flash:/GUI/dom.js
tftp-server flash:/GUI/downarrow.gif
tftp-server flash:/GUI/ephone_admin.html
tftp-server flash:/GUI/logohome.gif
tftp-server flash:/GUI/normal_user.html
tftp-server flash:/GUI/normal_user.js
tftp-server flash:/GUI/Plus.gif
tftp-server flash:/GUI/sxiconad.gif
tftp-server flash:/GUI/Tab.gif
tftp-server flash:/GUI/telephony_service.html
tftp-server flash:/GUI/uparrow.gif
tftp-server flash:/GUI/xml.template
tftp-server flash:/GUI/xml-test.html
tftp-server flash:/ccpexp
tftp-server flash:/ccpexp/external
tftp-server flash:/ccpexp/external/development-bundle
tftp-server flash:/ccpexp/external/development-bundle/themes
tftp-server flash:/ccpexp/external/development-bundle/themes/flick
tftp-server flash:/ccpexp/e/devopment-bundle/themes/flick/images/ui-bg_flat_0_eeeeee_40x100.png
tftp-server flash:/ccpexp/external/development-bundle/themes/flick/imat-bundle/themes/flick/images/ui-bg_highlight-soft_25_0073ea_1x100.png
tftp-server flash:/ccpexp/external/development-bundle/themeflick/images/ui-icons_ff0084_256x240.png
tftp-server flash:/ccpexp/external/development-bundle/themes/flick/images/ui-icons_ffffff_256x240.png
tftp-server flaleemes/flick/jquery.ui.button.css
tftp-server flash:/ccpexp/external/development-bundle/themes/flick/jquery.ui.coreui.heme.css
tftp-server flash:/ccpexp/external/js
tftp-server flash:/ccpexp/external/js/jquery-1.7.1.min.js
tftp-server flash:/ccpexp/html/bundles/ValidationMessages_fr.properties
tftp-server flash:/ccpexp/html/images/Signal2.png
tftp-server flash:/ccpexp/html/images/Signal3.png
tftp-server flash:/ccpexp/html/images/Signal4.png
tftp-server flash:/ccpexp/html/images/Signal5.png
tftp-server flash:/ccpexp/html/images/allImagesby40.png
tftp-server flash:/ccpexp/html/imaml/images/ceserver.png
tftp-server flash:/ccpexp/html/images/close.png
tftp-server flash:/ccpexp/html/images/disable.png
tftp-server flash:/ccpexp/html/images/down.png
tftp-server flash:/ccpexp/html/images/enable.png
tftp-server flash:/ccpexp/html/images/information.png
tftp-server flash:/ccpexp/html/dhcpDns.html
tftp-server flash:/ccpexp/html/frames.html
tftp-server flash:/ccpexp/html/framesEndUser.html
tftp-server flash:/ccpexp/html/iAndC.html
tftp-server flash:/ccpexp/html/jsNotEnabled.html
tftp-server flash:/ccpexp/html/navigationTemplate.html
tftp-server flash:/ccpexp/html/user.html
tftp-server flash:/ccpexp/html/wireless.html
tftp-server flash:/ccpexp/js
tftp-server flash:/ccpexp/js/l10n
tftp-server flash:/ccpexp/js/unittest
tftp-server flash:/ccpexp/odm
tftp-server flash:/ccpexp/odm/overviewshChatScript_HSPA7.txt
tftp-server flash:/ccpexp/templates/ChatScript_LTE.txt
tftp-server _NonDialerPersistent_HSPA7.txt
tftp-server flash:/ateDialer.txt
tftp-server flash:/ccpexp/templates/createInterface.txt
tftp-server flashtIaceDelete.txt
tftp-server flash:/ccpexp/templates/dest-netIpCreate.txt
tftp-server flash:/ccpexp/templates/hostnameDomainname.txt
tftp-server flash:/ccpexp/templaCPHostname.txt
tftp-server flash:/ccpexp/templates/interfaceWithIPNego.txt
tftp-server flpexp/templates/loopbackIpv6StaticIP.txt
tftp-server flash:/ccpexp/templates/loopbackStaticIP.txt
tftp-server flash:/ccpexp/templates/natInside.txt
tftp-server flash:/ccpexp/templates/noCdpRun.txt
tftp-server flash:/ccpexp/templates/noDslGroup0.txt
tftp-server flash:/ccpexp/templates/parserCLIDeleteAaaCommand.txt
tftp-server flash:/ccpexp/templates/paflash:/ccpexp/templates/setMTUSize.txt
tftp-server flash:/ccpexp/templates/shdslATM.txt
tftp-server flash:/ccpexp/templates/shdslAUTO.txt
tftp-server flash:/ccpexp/templates/shdslEFM.txt
tftp-server flash:/Open_Source_Documentation.html
tftp-server flash:/ccpexp/version.txt
tftp-server flash:/home.shtml
tftp-server flash:/its
tftp-server flash:/its/vrf1
tftp-server flash:/its/vrf1/XMLDefault7902.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault.xml
tftp-server flash:/its/vrf1/XMLDefault7925.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7931.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7935.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7936.cnf.xml
tftp-server flash:/its/vrf1/XM1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7940-7914-2.cnf.xml
tftp-server flash:/its/Default7960.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7960-7914-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7960-7915-12-1.cnf.xml
tftp-server flash flash:/its/vrf1/XMLDefault7961GE-7914-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7962-7916-24-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7962-7914-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7962-7915-1LDefault7965-7915-24-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7965-7916-12-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefaucnf.xml
tftp-server flash:/its/vrf1/XMLDefault7971.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7971-7916-24-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7975.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7975-7915-24-2.cnf.xml
tftp-server flash:/its/vrf1/Default6945.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault8941.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault8945.cnf.xml
tftp-server flash:sxiconad.gif
tftp-server flash:Tab.gif
tftp-server flash:Telephony_serv
tftp-server flash:/its/vrf1/XMLDefault7905.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7906.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7910.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7911.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7912.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7920.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7921.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7940.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7940-7914-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7940-7915-12-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7940-7915-24-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7940-7916-12-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7940-7916-24-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7940-7915-12-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7940-7915-24-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7940-7916-12-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7940-7916-24-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7941.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7941GE.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7942.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7945.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7960.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7960-7915-24-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7960-7916-12-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7960-7916-24-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7960-7914-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7960-7915-12-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7960-7915-24-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7960-7916-12-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7960-7916-24-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7961.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7961-7914-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7961-7915-12-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7961-7915-24-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7961-7916-12-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7961-7916-24-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7961-7914-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7961-7915-12-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7961-7915-24-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7961-7916-12-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7961-7916-2sh:/its/vrf1/XMLDefault7961GE-7915-12-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault796l/vrf1/XMLDefault7962-7916-24-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7965.cnf.xml
tftp-server flash:/its/vrf1/u915-24-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7965-7916-12-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7965--l
tftp-server flash:/its/vrf1/XMLDefault7970-7915-12-2.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7970-7915-sash:/its/vrf1/XMLDefault7971-7916-24-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7971-7914-2.cnf.xml
tftp-server flash:/its/vrf1//vrf1/XMLDefault7975-7915-24-1.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault7975-7916-12-1.cnf.xml
tftp-server flash:/its/vrf1/XMLCIPC.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault6941.cnf.xml
tftp-server flash:/its/vrf1/XMLDefault6961.cnf.xml
tftp-server flash:delete.gif
tftp-server flash:dom.js
tftp-server flash:downarrow.gif
tftp-server fla-0-4.SBN
tftp-server flash:B015-1-0-4.SBN alias B015-1-0-4.SBN
tftp-server flash:Admin-user.html
tftp-server flash:Admin_user.js
tftp-server flash:CiscoLogo.gif
tftp-server flash:ephone_admin.html
tftp-server flash:logohome.gif
tftp-server flash:normal_user.html
tftp-server flash:normal_user.js
tftp-server flash:Plus.gif
tftp-server flash:Telephony_service.html
tftp-server flash:uparrow.gif
tftp-server flash:xml.template
tftp-server flash:xml-test.html
tftp-server flash:admin_user.html
tftp-server flash:B015-1-0-4-2.SBN
tftp-server flash:APPATA187.9-2-3-1.img.sgn
tftp-server flash:ATA187.9-2-3-1.loads
tftp-server flash:BFSATA187.9-2-3-1.img.sgn
tftp-server flash:cmterm-ata187.9-2-3-1.cop.sgn
tftp-server flash:KNLATA187.9-2-3-1.bin.sgn
tftp-server flash:SCCP69xx.9-2-4-3.loads
tftp-server flash:cmterm-ata187.9-0-3-0.cop.sgn
tftp-server flash:cmterm-ata187-QED.cop.sgn
tftp-server flash:SCCP69xx.9-2-4-3.zz.sgn
tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:DSP69xx.0-0-0-11-124120.zz.sgn
control-plane
voice-port 0/0/0:0
voice-port 0/0/1:0
ccm-manager music-on-hold
mgcp profile default
dial-peer cor custom
name Fixo
name Celular
name DDD
name DDI
name Servicos
name 0X00
dial-peer cor list CSS-Fixo
member Fixo
member Servicos
member 0X00
dial-peer cor list CSS-Celular
member Fixo
member Celular
member Servicos
member 0X00
dial-peer cor list CSS-DDD
member Fixo
member Celular
member DDD
member Servicos
member 0X00
dial-peer cor list CSS-DDI
member Fixo
member Celular
member DDD
member DDI
member Servicos
member 0X00
dial-peer cor list PT-Fixo
member Fixo
dial-peer cor list PT-Celular
member Celular
dial-peer cor list PT-DDD
member DDD
dial-peer cor list PT-DDI
member DDI
dial-peer voice 1 voip
description ************************** Internal Calls **********************
destination-pattern 5...
session target ipv4:10.93.4.10
voice-class codec 1
dtmf-relay h245-alphanumeric
dial-peer voice 10 pots
corlist outgoing PT-Fixo
description ********************* Calls to Local *********************
destination-pattern 0[2-5].......
direct-inward-dial
port 0/0/0:0
forward-digits 8
dial-peer voice 11 pots
description description ********** Chamadas Conurbadas ******
preference 1
destination-pattern 001511........
direct-inward-dial
port 0/0/1:0
forward-digits 13
dial-peer voice 20 pots
corlist outgoing PT-Celular
description ********************* Calls to Mobile *********************
preference 1
destination-pattern 07.......
direct-inward-dial
port 0/0/0:0
forward-digits 8
dial-peer voice 21 pots
direct-inward-dial
port 0/0/1:0
forward-digits 8
dial-peer voice 22 pots
description ********************* Calls to Mobile - 9 Dig ******************
preference 1
destination-pattern 09........
direct-inward-dial
port 0/0/0:0
forward-digits 9
dial-peer voice 23 pots
direct-inward-dial
port 0/0/1:0
forward-digits 9
dial-peer voice 30 pots
description ********************* Calls to DDD *********************
translation-profile outgoing Incluir_DDD
destination-pattern 00[3-9].........
direct-inward-dial
port 0/0/0:0
forward-digits 13
dial-peer voice 31 pots
preference 1
direct-inward-dial
port 0/0/1:0
forward-digits 13
dial-peer voice 32 pots
description ********************* Calls to DDD SP - 9 Digitos **************
destination-pattern 001[1-9]9........
direct-inward-dial
port 0/0/0:0
forward-digits 14
dial-peer voice 33 pots
preference 1
direct-inward-dial
port 0/0/1:0
forward-digits 14
dial-peer voice 34 pots
description ********************* Calls to DDD SP  Cel-Local **************
destination-pattern 001[1-9][2-6].......
direct-inward-dial
port 0/0/0:0
forward-digits 13
sip-ua
authentication username cisco password 7 02050D480809
mwi-server ipv4:10.93.4.11 expires 3600 port 5060 transport udp
registrar ipv4:10.93.4.10 expires 3600
presence enable
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 58
max-dn 300
ip source-address 10.93.4.10 port 2000
timeouts interdigit 5
system message Client
cnf-file location flash:
load 7915-12 B015-1-0-4.SBN
load 7937 apps37sccp.1-4-5-7.bin
load 7942 SCCP42.9-3-1SR2-1S.loads
load ata ATA187.9-2-3-1.loads
load 6921 SCCP69xx.9-2-4-3.loads
load 6901 SCCP6901.9-3-1-SR1-3.loads
voicemail 5000
max-conferences 8 gain -6
moh "music-on-hold.au"
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Jan 15 2014 20:36:41
ephone-template  1
softkeys hold  Newcall Resume
softkeys idle  Redial Newcall Pickup Cfwdall Dnd
softkeys alerting  Endcall
softkeys connected  Hold Endcall Trnsfer Confrn ConfList
softkeys ringing  Answer Dnd
type 7962 addon 1 7915-12
end
All looks in place can you share a debug tftp events please
Have you tried adding the cme ip manually via the ivr on the ata?
Voice CCIE #37771
Hello Hermanus.
The only test that I didn´t do it was to configure manually the IP by IVR.
I don´t have remote access to this client and he already complained my company because I didnt get the solution fast, so my supervisor decided to open a Tac´s ticket to resolve it.
Anyway,tks so much for you share your time and for have a look in my configuration.
When I get the solution I´ll share here because for sure someone will get the same problem.
Today I acessed the router here is the debug tftp events.
Intl-BR-FM01-CoreRt#
Intl-BR-FM01-CoreRt#debug tftp events
TFTP Event debugging is on
Jan 20 21:04:25.451: TFTP: Looking for XMLDefault.cnf.xml
Jan 20 21:04:25.455: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 7, size 3556 for process 30
Jan 20 21:04:25.467: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 30
Jan 20 21:04:27.763: TFTP: Looking for CTLSEP6803C021FB01.tlv
Jan 20 21:04:27.991: TFTP: Looking for ATA6803C021FB01.cnf.xml
Jan 20 21:04:28.207: TFTP: Looking for XMLDefault.cnf.xml
Jan 20 21:04:28.207: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 7, size 3556 for process 30
Jan 20 21:04:28.219: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 30
Jan 20 21:04:30.511: TFTP: Looking for CTLSEP0C6803C021FB.tlv
Jan 20 21:04:30.739: TFTP: Looking for ATA0C6803C021FB.cnf.xml
Jan 20 21:04:30.943: TFTP: Looking for XMLDefault.cnf.xml
Jan 20 21:04:30.947: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 7, size 3556 for process 30
Jan 20 21:04:30.955: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 30
Jan 20 21:04:33.267: TFTP: Looking for CTLSEP6803C021FB01.tlv
Jan 20 21:04:33.487: TFTP: Looking for ATA6803C021FB01.cnf.xml
Jan 20 21:04:33.707: TFTP: Looking for XMLDefault.cnf.xml
Jan 20 21:04:33.707: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 7, size 3556 for process 30
Jan 20 21:04:33.719: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 30
Jan 20 21:04:36.023: TFTP: Looking for CTLSEP0C6803C021FB.tlv
Jan 20 21:04:36.251: TFTP: Looking for ATA0C6803C021FB.cnf.xml
Jan 20 21:04:36.463: TFTP: Looking for XMLDefault.cnf.xml
Jan 20 21:04:36.467: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 7, size 3556 for process 30
Jan 20 21:04:36.475: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 30
Jan 20 21:04:38.783: TFTP: Looking for CTLSEP6803C021FB01.tlv
Jan 20 21:04:39.007: TFTP: Looking for ATA6803C021FB01.cnf.xml
Jan 20 21:04:39.215: TFTP: Looking for XMLDefault.cnf.xml
Jan 20 21:04:39.215: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 7, size 3556 for process 30
Jan 20 21:04:39.239: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 30
Jan 20 21:04:41.531: TFTP: Looking for CTLSEP0C6803C021FB.tlv
Jan 20 21:04:41.759: TFTP: Looking for ATA0C6803C021FB.cnf.xml
Jan 20 21:04:41.963: TFTP: Looking for XMLDefault.cnf.xml
Jan 20 21:04:41.967: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 7, size 3556 for process 30
Jan 20 21:04:41.975: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 30
Jan 20 21:04:44.283: TFTP: Looking for CTLSEP6803C021FB01.tlv
Jan 20 21:04:44.507: TFTP: Looking for ATA6803C021FB01.cnf.xml
Jan 20 21:04:44.723: TFTP: Looking for XMLDefault.cnf.xml
Jan 20 21:04:44.727: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 7, size 3556 for process 30
Problem FIXED!!!! Aleluia!!!
My dear Engineers, after open the Cisco's TAC and get some time, here is the solution:
It was took off two extra firmware from the Old Configuration:
It was created two register pool because the customer were using two lines in the ATA 187
It was configured to the ATA use voice-class codec 1
It was took off the firmware's ATA from the telephony-service
Old Configuration
mode cme
source-address 10.93.4.5 port 5060
max-dn 10
max-pool 20
timezone 17
camera
video
voice register dn  2
number 5533
allow watch
name Fax 2
label Fax 2
voice register dn  3
number 5533
allow watch
name Fax 1
label Fax 1
ata-ivr-pwd 1234
type ATA-187
number 1 dn 2
number 2 dn 3
telephony-service
no auto-reg-ephone
max-ephones 58
max-dn 300
ip source-address 10.93.4.5 port 2000
system message Cliente
voicemail 5000
web admin system name admin secret 5 $1$4Vf/$3h4yCXho9g8cPs6q3f0ZZ1
dn-webedit
time-webedit
create cnf-fil
New configuration
mode cme
max-dn 10
max-pool 20
timezone 17
  tftp-path flash:
create profile sync 0233201242050044
camera
video
voice register dn  2
number 5533
allow watch
name Fax 2
label Fax 2
voice register dn  3
number 5562
allow watch
name Fax 1
label Fax 1
voice register pool  4
id mac 0C68.03C0.21FB
type ATA-187
number 1 dn 2
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
username cisco4 password cisco4
voice register pool  5
id mac 6803.C021.FB01
type ATA-187
number 1 dn 3
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
username cisco5 password cisco5
telephony-service
no auto-reg-ephone
max-ephones 58
max-dn 300
cnf-file perphone
voicemail 5000
dn-webedit
time-webedit
create cnf-files version-stamp Jan 01 2002 00:00:00
The Debug's commands that were used are here:
debug voip ccapi inout
debug ccsip messages
debug csip events
debug ccsip media
debug ccsip error
debug ccsip info
I hope these informations can help some Engineer in the future
914
