10-28-2013 10:43 AM - edited 03-16-2019 08:06 PM
Dear All,
Here is the call flow for failed fax :
ATA 187---------- CUCM 8.5 ----------2951 SIP CUBE------------ITSP
We have SIP link and a CUBE router, everything is working fine apart from the fax. Can someone please give me some sample config
Solved! Go to Solution.
10-30-2013 03:19 PM
Well, I would say, if they support t.38, then use it:
dial-peer voice 1 voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through
fax-relay ecm disable
fax nsf 000000
fax-relay sg3-to-g3
Configure ATA to t.38
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
10-29-2013 12:02 AM
You can just add ATA as a device/phone in CUCM and use the existing dial-peers for other phones.
Fax Mode "Fax pass-through" worked perfect for me on both ways and I needed to have
voice service voip
fax protocol pass-through g711ulaw
Cheers,
10-29-2013 07:19 AM
First of all, you need to clarify what faxing protocol is your ITSP supporting, Pass-Through or T.38.
If T.38:
CUBE Dial-peers:
fax nsf 000000
fax-relay sg3-to-g3
If Pass-Through:
CUBE Dial-peers:
Configure ATA to Passthorugh.
Please make sure MTP is not allocated for fax transmition, it will break it.
Jorge Armijo
10-30-2013 03:01 AM
Hi Jorge,
Thanks dear I will apply this settings and will let you know, how did that go? Also, I will check first with ITSP what protocol they support?
10-30-2013 06:07 AM
Hi Jorge,
Please see below response of the ITSP, can you please suggest do I need amendment in the above script?
Just checked with ITSP and they support:
10-30-2013 03:19 PM
fax nsf 000000
fax-relay sg3-to-g3
Jorge Armijo
11-04-2013 07:51 AM
Jorge Armijo
11-04-2013 08:01 AM
Hi Jorge,
Actually change should go through the change board, so plan is to apply change tomorrow, finger cross
One again thanks for your help, I will update you tomorrow how did this go.
11-04-2013 08:08 AM
Sounds good, let us know how it goes.
Jorge Armijo
11-17-2013 09:07 PM
Any luck?
Jorge Armijo
12-11-2013 02:33 AM
Hi Jorge,
Sorry for replying you bit late, just want to thanks to you for your help. All working fine
09-11-2014 02:05 AM
Hi all,
I have issue with internal fax (extension to extension) I configured SPA122 as anlog adapter and im able ring between fax machine. when try to send disconnected after ringing. i tried both ways using extension numbers but no luck.
fax -->spa122-->cucm8.6-->spa122-->fax
cucm version is 8.6
first I need to setup internal fax and then I want to try for external fax.
any suggestion to correct my mistakes.
thanks,
