Dear All,
Here is the call flow for failed fax :
ATA 187---------- CUCM 8.5 ----------2951 SIP CUBE------------ITSP
We have SIP link and a CUBE router, everything is working fine apart from the fax. Can someone please give me some sample config
Solved! Go to Solution.
Well, I would say, if they support t.38, then use it:
dial-peer voice 1 voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through
fax-relay ecm disable
fax nsf 000000
fax-relay sg3-to-g3
Configure ATA to t.38
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
You can just add ATA as a device/phone in CUCM and use the existing dial-peers for other phones.
Fax Mode "Fax pass-through" worked perfect for me on both ways and I needed to have
voice service voip
fax protocol pass-through g711ulaw
Cheers,
First of all, you need to clarify what faxing protocol is your ITSP supporting, Pass-Through or T.38.
If T.38:
CUBE Dial-peers:
fax nsf 000000
fax-relay sg3-to-g3
If Pass-Through:
CUBE Dial-peers:
Configure ATA to Passthorugh.
Please make sure MTP is not allocated for fax transmition, it will break it.
Jorge Armijo
Hi Jorge,
Thanks dear I will apply this settings and will let you know, how did that go? Also, I will check first with ITSP what protocol they support?
Hi Jorge,
Please see below response of the ITSP, can you please suggest do I need amendment in the above script?
Just checked with ITSP and they support:
fax nsf 000000
fax-relay sg3-to-g3
Jorge Armijo
Jorge Armijo
Hi Jorge,
Actually change should go through the change board, so plan is to apply change tomorrow, finger cross
One again thanks for your help, I will update you tomorrow how did this go.
Sounds good, let us know how it goes.
Jorge Armijo
Any luck?
Jorge Armijo
Hi Jorge,
Sorry for replying you bit late, just want to thanks to you for your help. All working fine
Hi all,
I have issue with internal fax (extension to extension) I configured SPA122 as anlog adapter and im able ring between fax machine. when try to send disconnected after ringing. i tried both ways using extension numbers but no luck.
fax -->spa122-->cucm8.6-->spa122-->fax
cucm version is 8.6
first I need to setup internal fax and then I want to try for external fax.
any suggestion to correct my mistakes.
thanks,
