09-19-2013 08:18 PM - edited 03-16-2019 07:28 PM
Hey All,
Im connecting an ATA 187 to a Multi-Function Machine to allows Faxes inbound.outbound etc. I have rolled a few so far, however Im having trouble with one fax machine where the Line on the ATA is always busy. If I disconnect the cabel between the fax and the ATA, obviously the Line light goes off.. As soon as I plug the cable in.. Line LED lights up and line is busy. I have tried the second line.
Im thinking the ATA may be having issues or the actual Fax Machine needs some adjustments.
Any thoughts?
Cheers
Ben
09-19-2013 10:19 PM
Hi Ben.
Is the ATA correctly registered to CUCM/CME?
What kind of platform are you running?
Let us know?
Carlo
09-19-2013 10:50 PM
Hey,
Yes the ata is registered to CUCM. I tried the second line as well, same affect. The line just went into busy mode as soon as I connected the fax.
Platform is CUCM 9.1
Cheers
Ben
09-19-2013 11:26 PM
Check the cable. You must use a two wires cable (tip and ring). If you have a four wires cable you must replace it with a two wires.
Check the fax interface. Tipically, faxes have a line port and a phone port. The ATA must be connected to line port.
Regards.
09-20-2013 02:12 PM
Is the ATA registered to the CUCM
If yes, please advise the fw version of it
Haitham
09-23-2013 04:56 PM
Hey Haitham,
ATA Firmware is ATA187.9-2-3-1
CUCM Version is 9.1.1.20000-5
I just connected another ATA, using 4 wire cable, same firmeware same cluster and worked fine.. Im thinking the ATA must be faulty?
Cheers
Ben
