ATA 187 on gateway 3925
   I need your help in setting up/configuring the ATA 187 on gateway 3925 router for fax services.
Ali
Can you give us more details about your setup, i don't understand what you mean by ATA on 3925 router??? do you mean you have CME ?
Amer
Yes Amer I mean CME.
Ali
Ali,
What is the version for CME you are running?
ATA 187 is only supported on CME 9.0
Amer
If you have CME version 9.0 or later , here is the config :
Configuring Voice and T.38 Fax Relay on Cisco ATA-187
To configure voice and T.38 Fax Relay on Cisco ATA-187, perform the following steps.
Prerequisites
Cisco Unified CME 9.0 or a later version.
Restrictions
H.323 trunk calls are not supported.
Hardware  conferencing with DSPFarm resource is not supported on Cisco ATA-187 in  Cisco Unified CME 9.0. With the correct firmware (9.2(3) or a later  version), local three-way conferencing is supported.
SUMMARY STEPS
1. enable
2. configure terminal
3. voice register global
4. authenticate realm string
5. exit
6. voice service {voip | voatm}
7. allow-connections from-type to to-type
8. fax protocol t38 [ls_redundancy value [hs_redundancy value]] [fallback {cisco | none | pass-through {g711ulaw | g711alaw}}]
9. exit
10. voice register pool pool-tag
11. id mac address
12. type phone-type
13. ata-ivr-pwd password
14. session-transport {tcp | udp}
15. number tag dn dn-tag
16. username username [password password]
17. codec codec-type [bytes]
Detailed Config :
DETAILED STEPS
Command or Action
Purpose
Step 1
enable
Example:
Router> enable
Enables privileged EXEC mode.
Enter your password if prompted.
Step 2
configure terminal
Example:
Router# configure terminal
Enters global configuration mode.
Step 3
Example:
Router(config)# voice register global
Enters voice register global configuration mode.
Step 4
Example:
Router(config-register-global)# authenticate  realm xxxxx
realm string—Realm parameter for challenge and response as specified in RFC 2617 is authenticated.
Step 5
exit
Example:
Router(config-register-global)# exit
Exits voice register global configuration mode.
Step 6
Example:
Router(config)# voice service voip
Enters voice-service configuration mode to specify a voice encapsulation type.
voip—Specifies Voice over IP (VoIP) parameters.
voatm—Specifies Voice over ATM (VoATM) parameters.
Step 7
Example:
Router(config-voi-serv)# allow-connections sip  to sip
Allows connections between specific types of endpoints in a VoIP network.
from-type—Originating endpoint type. The following choices are valid:
sip—Session Interface Protocol.
to—Indicates that the argument that follows is the connection target.
to-type—Terminating endpoint type. The following choices are valid:
Step 8
Example:
Router(config-voi-serv)# fax protocol t38  ls-redundancy 0 hs-redundancy 0 fallback  pass-through g711ulaw
Specifies the global default ITU-T T.38 standard fax protocol to be used for all VoIP dial peers.
ls_redundancy value—  (Optional) (T.38 fax relay only) Specifies the number of redundant T.38  fax packets to be sent for the low-speed V.21-based T.30 fax machine  protocol. Range varies by platform from 0 (no redundancy) to 5 or 7.  Default is 0.
hs_redundancy value—  (Optional) (T.38 fax relay only) Specifies the number of redundant T.38  fax packets to be sent for high-speed V.17, V.27, and V.29 T.4 or T.6  fax machine image data. Range varies by platform from 0 (no redundancy)  to 2 or 3. Default is 0.
fallback—(Optional)  A fallback mode is used to transfer a fax across a VoIP network if T.38  fax relay could not be successfully negotiated at the time of the fax  transfer.
pass-through—(Optional) The fax stream uses one of the following high-bandwidth codecs:
g711ulaw—Uses the G.711 u-law codec.
g711alaw—Uses the G.711 a-law codec.
Step 9
exit
Example:
Router(config-voi-serv)# exit
Exits voice-service configuration mode.
Step 10
Example:
Router(config)# voice register pool  11
Enters voice register pool configuration mode to set phone-specific  parameters for a Cisco Unified SIP phone in Cisco Unified CME.
pool-tag—Unique number assigned to the pool. Range: 1 to 100.
Step 11
id mac address
Example:
Router(config-register-pool)# id mac  93FE.12D8.2301
Identifies a locally available Cisco Unified SIP IP phone.
mac address—Identifies the MAC address of a particular Cisco Unified SIP IP phone.
Step 12
type phone-type
Example:
Router(config-register-pool)# type ATA-187
Defines a phone type for the SIP phone being configured.
Step 13
Example:
Router(config-register-pool)# ata-ivr-pwd 1234
(Optional) Defines a password to access interactive voice response (IVR)  and change the default phone settings on Cisco Analog Telephone  Adaptors.
password—Four-digit or five-digit string to be used as password to access IVR. Password string must contain numbers 0 to 9.
Step 14
Example:
Router(config-register-pool)# session-transport  tcp
(Optional) Specifies the transport layer protocol that a Cisco Unified SIP IP phone uses to connect to Cisco Unified CME.
tcp—Transmission Control Protocol (TCP) is used.
udp—User Datagram Protocol (UDP) is used. This is the default.
Step 15
Example:
Router(config-register-pool)# number 1 dn 33
Indicates the E.164 phone numbers that the registrar permits to handle the Register message from the Cisco Unified SIP IP phone.
tag—Identifies the telephone number when there are multiple number commands. Range: 1 to 10.
dn dn-tag—Identifies the directory number tag for this phone number as defined by the voice register dn command. Range: 1 to 150.
Step 16
Example:
Router(config-register-pool)# username ata112  password cisco
Assigns an authentication credential to a phone user so that the SIP phone can register in Cisco Unified CME.
username—Username of the local Cisco IP phone user. Default: Admin.
password—Enables password for the Cisco IP phone user.
password—Password string.
Step 17
Example:
Router(config-register-pool)# codec g711ulaw
Specifies the codec to be used when setting up a call for a SIP phone or group of SIP phones in Cisco Unified CME.
codec-type—Preferred codec; values are as follows:
g711alaw—G.711 A-law 64K bps.
g711ulaw—G.711 micro-law 64K bps.
g722r64—G.722-64K at 64K bps.
g729r8—G.729 8K bps (default).
ilbc—internet Low Bitrate Codec (iLBC) at 13,330 bps or 15,200 bps.
Step 18
end
Example:
Router(config-register-pool)# end
Exits to privileged EXEC mode.
Amer
842
