ATA 187 por 2 not registering in SRST mode
i have ATA 187 registered in its two ports with CUCM 8.0(3) and i have VG 2921 with SRST version 8.1 i configured a voice register pool for each port as follows:
voice register pool 1
id mac 0012.7F3B.9025
number 1 2800
codec g711ulaw
voice register pool 2
id mac 127F.3B90.2501
number 1 2801
codec g711ulaw
the above MAC is just an example. if ATA MAC is 0012.7F3B.9025 then this will be for port 1 which is registering fine and 127F.3B90.2501 will be for the second port as the way it is registering with CUCM server.
my issue is that the second port in ATA is not registering in the SRST gateway. Iam not sure if something is missing on my configuration.
regards,
Ibrahim
  • IP Telephony
Re: ATA 187 por 2 not registering in SRST mode
any support please
regards,
Ibrahim
If you get a packet capture off the ATA, do you see the ATA send a REGISTER for the second port?  Do you see a SIP REGISTER for that port come in the SRST router with 'debug ccsip mess'?
It may be that only registration of the first port is supported with SIP ATAs to SIP SRST.  I've never tested it to verify behavior, personally.
Hi Steven,
when the ATA is in SRST mode, i checked the SIP statistics with "show voice register pool 1" and "show voice register pool 2"
for pool 1 i see the sip requests and registration while on the pool 2 there is nothing (not even a request). I am not sure if i configured the second port correctly since i did not see any cisco document stating how to configure that on the gateway.
i will try to check with 'debug ccsip mess'. it is stated in cisco that ATA 187 is not supported officialy in CME until summer 2011 but nothing mentioned about SRST mode.
regards,
Ibrahim
Now it is working great. I did some debug messages and troubleshooting and i modified the configuration as follows:
id mac D057.4C6B.DC7B
number 1 2010
cor incoming Local-CSS default
codec g711ulaw
or simply the following:
number 1 2010
number 2 2011
codec g711ulaw
so the gateway register the two ports with the same mac address.
regards,
Ibrahim
number 1 2010
codec g711ulaw
Hall of Fame Super Red
Hi Ibrahim,
Thanks for posting back with these interesting results
+5 for sharing this info that will help others going forward.
Cheers!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
thanks Rob. I like the team work and it is very nice to share information with others specialy in new stuf.
regards,
Ibrahim
2031
