05-28-2014 02:32 PM - edited 03-16-2019 10:55 PM
05-28-2014 04:02 PM
I am not a hundred percent sure, but try connecting a phone to the ATA 187 port 1, and press the Setup button. This should start up an IVR on the ata. Default pin is 24726. This should take you to a menu where you can configure larger settings on the ata.
05-29-2014 12:49 PM
You should be getting the following options:
Action | IVR Code | Navigating Notes |
Review or Set Network Settings | 1 | If DHCP is enabled, the IVR announces each network parameter. If DHCP is disabled, the IVR announces each network parameter, pausing in between to allow you to enter a new value. 1. IVR announces the IP Address. To change the IP address for the phone, use the keypad to enter a new IP address, followed by the #. To retain the current IP address, press #. 2. IVR announces the subnet mask. To change the subnet mask use the keypad to enter a new IP address, followed by the #. To retain the current subnet mask, press #. Note To enter the dot "." that separates each octet in the IP address, press *. 3. IVR announces the default gateway. To change the default gateway, use the keypad to enter a new IP address, followed by the #. To retain the current default gateway, press #. |
Review or Set TFTP Server | 2 | IVR announces the current TFTP setting. To change the TFTP server, use the keypad to enter a new IP address, followed by the #. To retain the current TFTP server, press #. To reset a TFTP server back to the TFTP server set by the DHCP server from a manually configured TFTP server, press *. Note To enter the dot "." that separates each octet in the IP address, press *. |
Enable or Disable DHCP | 3 | Press 3 to toggle DHCP to enable or disable. |
Review or Set the VLAN ID | 4 | Press 4 to review and set the Administrator VLAN ID. |
Reset to factory settings | 0 | — Note All configuration settings will reset to default factory settings, the and phone will reset. It will take some time for the phone to re-register. Select this option only when needed. |
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cata/187/1_0/english/administration/guide/sip/187adm80/a187_agBcd.html
No separate option for deleting ITL/CTL files, You will to use factory reset, but ensure you have all the configuration pre-hand, such as ip, VLAN ,tftp etc
05-28-2014 04:02 PM
05-28-2014 05:42 PM
Thanks for the response.
Where is the setup button in the analog phone.(port 1 is the fxs port).
05-28-2014 10:13 PM
The setup button is on the ata, not on the analog phone.
You will have to go off-hook on the first line of the ata and then press the setup button on the ata 187.
05-29-2014 12:05 PM
I could not see the setup button in ATA 187.
please help me.
05-29-2014 12:23 PM
It's the right most LED on the front of your ATA
Aditya
05-29-2014 12:29 PM
Thanks for the replay.
Could you please send me the picture?
05-29-2014 12:34 PM
05-29-2014 12:40 PM
Hi aditgup,
ITL -CTL option is there in the IVR menu?
05-29-2014 12:49 PM
05-29-2014 01:42 PM
Thanks you all
