ATA 187 remove ITL CTL files
Hi tecizzz,
How to delete ITL CTL files in ATA 187.
2 ACCEPTED SOLUTIONS
I am not a hundred percent
I am not a hundred percent sure, but try connecting a phone to the ATA 187 port 1, and press the Setup button. This should start up an IVR on the ata. Default pin is 24726. This should take you to a menu where you can configure larger settings on the ata.
HiYou should be getting the
You should be getting the following options:
 Navigating the IVR Configuration Menu
Action
IVR Code
Navigating Notes
Review or Set Network Settings
If DHCP is enabled, the IVR announces each network parameter.
If DHCP is disabled, the IVR announces each network parameter, pausing in between to allow you to enter a new value.
1. IVR announces the IP Address. To change the IP address for the phone, use the keypad to enter a new IP address, followed by the #. To retain the current IP address, press #.
2. IVR announces the subnet mask. To change the subnet mask use the keypad to enter a new IP address, followed by the #. To retain the current subnet mask, press #.
Note To enter the dot "." that separates each octet in the IP address, press *.
3. IVR announces the default gateway. To change the default gateway, use the keypad to enter a new IP address, followed by the #. To retain the current default gateway, press #.
Review or Set TFTP Server
IVR announces the current TFTP setting.
To change the TFTP server, use the keypad to enter a new IP address, followed by the #. To retain the current TFTP server, press #.
To reset a TFTP server back to the TFTP server set by the DHCP server from a manually configured TFTP server, press *.
Enable or Disable DHCP
Press 3 to toggle DHCP to enable or disable.
Review or Set the VLAN ID
Press 4 to review and set the Administrator VLAN ID.
Reset to factory settings
Note All configuration settings will reset to default factory settings, the and phone will reset. It will take some time for the phone to re-register. Select this option only when needed.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cata/187/1_0/english/administration/guide/sip/187adm80/a187_agBcd.html
No separate option for deleting ITL/CTL files, You will to use factory reset, but ensure you have  all the configuration pre-hand, such as ip, VLAN ,tftp etc
Thanks for the response.Where
Where is the setup button in the analog phone.(port 1 is the fxs port).
The setup button is on the
The setup button is on the ata, not on the analog phone.
You will have to go off-hook on the first line of the ata and then press the setup button on the ata 187.
I could not see the setup
I could not see the setup button in ATA 187.
please help me.
It's the right most LED on
It's the right most LED on the front of your ATA
Aditya
Thanks for the replay.Could
Could you please send me the picture?
attached
attached
Hi aditgup,ITL -CTL option is
Hi aditgup,
ITL -CTL option is there in the IVR menu?
Action
IVR Code
Navigating Notes
Thanks you all
Thanks you all
920
