ATA-187 Shared Lines, Max Num of Calls
CUCM 8.6.1
ATA-187 9.2(1)
Currently as it seems CUCM only allows you to configure at most a Maximum Number of Calls of 2 under the line configuration for an ATA-187. Is there any way to increase this number greated than 2?
You run into a problem if you want to configure the line for a fxs port on the ATA-187 to be a shared line. If it's a shared line with two phones (e.g. FXS port 1 and port 2 on the ATA) you lose call waiting and the ability to handle more than one call on a phone since you would want to configured the busy trigger as 1 for both. If it's a shared line with three phones (e.g. FXS port 1 and 2 and an IP phone) you can run into the situation that a port on the ATA would be unusable if the other port on the ATA is active along with the other shared line on the IP Phone is active.
Everyone's tags (6)
459
