ATA-187 with GAI callbox dials repeatedly
We have some ATAs connected to callboxes around a campus. The ATA is in the closet and the callbox is remote on a sidewalk.
Is there some exact tools your techs have to check for ground/wiring issues at the callbox out on the sidewalk?
We’ve had some callboxes that go offhook, then onhook, then offhook, then onhook. Since the ATA is setup for a CSS with PLAR it generates 3 calls to 911. We unplugged the GAI callbox and plugged a butt set out on the side walk and the same thing happened. I suspect the problem might be a bad ground/wiring issue but what tools can we use to prove that it’s a wiring issue instead of an ATA-187 issue?
I pulled the CDR and RTMT/Trace file and see the 3 rapid calls.
CallManager 9.1.1.21018-1
ATA187.9-2-3SR1-1  (SIP)
Everyone's tags (6)
184
