01-17-2007 12:07 AM - edited 03-14-2019 07:34 PM
Dear all,
somehow I have problems if I use an ATA and a hp k1220 fax. if I send to the outside world it works, but if I send internal (via callmanager) I get an communication error (error 386).
any suggestions?
(it seems I also have this problem with a canon g3 fax)
gerard
01-23-2007 07:09 AM
Have you tested other fax machines with the ATA? One thing to keep in mind is that the ATA can only operate in Fax Passthrough mode or Fax Mode, both of which are different than Fax Relay
01-26-2007 03:05 AM
I have replaced the HP fax with a canon fax. this does work.
but unfortunatly I still hava lot of hp faxes, and I don't want to replace them all..
I've turne off ecm. but still problems. Are there settings I need to change on the ATA?
I did find some information, but those are different pages then the one my ata has.
suggestions?
regards,
Gerard
01-26-2007 04:38 AM
btw.. I have version :3.2.3 SCCP runing on my ata
it sometime comes trough though.
