01-15-2009 04:28 AM - edited 03-15-2019 03:32 PM
Hello everibody,
I'm using an ATA with UC520 for FAX handling and is working correctly.
The codec I use is 711.
Now I want to enable the second port on the same ATA and apply an internal number to it.
I tried with button 2:num but it doesn't work.
If I lift the telephon I hear no tone, the ATA shows a red light and nothing happens.
Can anybody help me?
Solved! Go to Solution.
01-15-2009 04:36 AM
Do "show ephone summary" - you will see the ATA registers as second ephone with the same MAC address shifted with 01 added at the end. Use this second ephone to configure as you like.
01-15-2009 04:36 AM
01-15-2009 06:46 AM
Hi, unfortunately I can't see any mac shifted with 01. this is the output of my sh ephone summary:
ephone-5 Mac:0022.9004.0821 TCP socket:[2] activeLine:0 REGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 50*
IP:10.1.1.11 ATA Phone keepalive 29454 1:50
ephone-6 Mac:0022.9004.0819 TCP socket:[22] activeLine:0 REGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 2*
IP:10.1.1.38 ATA Phone keepalive 265 1:2
they are my two ATAs, one registered with ephone-dn 50 and the other with 2
do I have to set anything in the web interface of my atas?
01-15-2009 06:53 AM
I also have the following information:
ephone-40 Mac:0021.553E.02D9 TCP socket:[19] activeLine:0 REGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 40*
IP:10.1.1.25 7921 keepalive 618 1:40
Max 40, Registered 17, Unregistered 2, Deceased 0, Sockets 20
ephone_send_packet process switched 0
Standby socket list (no registered device):
[4]: 10.1.1.38 14967 [6]: 10.1.1.11 2634
[20]: 10.1.1.25 1026
which shows no registered devices (my atas but also my 7921 and I don't know why it results not registered)
01-15-2009 07:06 AM
Very good,
i registered a the second port with the mac shifted and now it works!
Thank you very much
01-15-2009 10:38 AM
You must have had auto-registration off so you didn't saw it first.
Thanks for the nice rating and good luck!
