ATA enabling second port with UC500 UC520
l.buschi
Level 2
Level 2
Hello everibody,
I'm using an ATA with UC520 for FAX handling and is working correctly.
The codec I use is 711.
Now I want to enable the second port on the same ATA and apply an internal number to it.
I tried with button 2:num but it doesn't work.
If I lift the telephon I hear no tone, the ATA shows a red light and nothing happens.
Can anybody help me?
paolo bevilacqua
Do "show ephone summary" - you will see the ATA registers as second ephone with the same MAC address shifted with 01 added at the end. Use this second ephone to configure as you like.
5 Replies 5
paolo bevilacqua
Hi, unfortunately I can't see any mac shifted with 01. this is the output of my sh ephone summary:
ephone-5 Mac:0022.9004.0821 TCP socket:[2] activeLine:0 REGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 50*
IP:10.1.1.11 ATA Phone keepalive 29454 1:50
ephone-6 Mac:0022.9004.0819 TCP socket:[22] activeLine:0 REGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 2*
IP:10.1.1.38 ATA Phone keepalive 265 1:2
they are my two ATAs, one registered with ephone-dn 50 and the other with 2
do I have to set anything in the web interface of my atas?
I also have the following information:
ephone-40 Mac:0021.553E.02D9 TCP socket:[19] activeLine:0 REGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 40*
IP:10.1.1.25 7921 keepalive 618 1:40
Max 40, Registered 17, Unregistered 2, Deceased 0, Sockets 20
ephone_send_packet process switched 0
Standby socket list (no registered device):
[4]: 10.1.1.38 14967 [6]: 10.1.1.11 2634
[20]: 10.1.1.25 1026
which shows no registered devices (my atas but also my 7921 and I don't know why it results not registered)
Very good,
i registered a the second port with the mac shifted and now it works!
Thank you very much
You must have had auto-registration off so you didn't saw it first.
Thanks for the nice rating and good luck!
