Community Member
ATA FAX Route pattern discard digit
Using ATA for sending fax in a client place, to give password for ATA, I have create a dial pattern 12345.00!#, the 12345 works but when the fax give report it says the dail pattern as 1234500....., how to discard the unwanted digit [12345] in fax report.
VIP Purple
Re: ATA FAX Route pattern discard digit
Use the PreDot DDI at the route list level.
Hope this helps.
Brandon
Community Member
Already I have apply predot, when call going out it removing the unwanted digit, but when the fax give transmission output, it give all the dialed number, including the four digt.
123400xxxxxxxxxxx
COuld please let me know how to avoid discard the four digit in fax report also
VIP Purple
Did you apply PreDot at the route pattern or route list level? Be sure to apply it at the route list if you do not want the digits before the . to show up in the CDR.
Brandon
104
