Community Member
ATA Fax
Hi Guys,
I am having the exact same problem as posting http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc12f69 with the execption i am using 3 bri`s instead of an E1. I have checked all the ATA and gateway settings to match that in the above posting. This has not made any difference tho for me.For the network clock select command i have used BRI 0/1/1 ....i am using H.323....
Any ideas ??
Silver
Re: ATA Fax
What happen when you call the DN number of your fax machine? post your Router config here. Check also if your ATAs are in the right Device pool, CSS/Partition. There is also a tool called "preserv.exe" which can help you troubleshoot your ATA( see here for more infos:
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_configuration_example09186a00800d698e.shtml)
Community Member
Re: ATA Fax
Hi Guys,
I still have this issue ongoing. Any help would be appreciated. Please see some of my debugs in the attachment :
249
