Community Member
ATA H323 and CME send fax but receive
Hi, I'm Fernando from Spain so I have configured settings for Europe.
I have a problem when receiving faxes.Sending fax is ok.
I've configured fax as FAX MODE, The parameters in ATA are:
audio mode:0x00120012
connect mode: 0x90002400
In CME i have in dial-peer the following :
dial-peer voice 9376 voip
description *** Outgoing Fax Calls ***
huntstop
destination-pattern 9977
no modem passthrough
session target ipv4:192.168.0.24
incoming called-number 914399977
fax-relay sg3-to-g3
fax rate disable
no vad
Thank you
Fernando
Hall of Fame Super Gold
Re: ATA H323 and CME send fax but receive
does the FAX answer when you call 9977 ?
Is the call coming from ISDN and how are handling DID ?
Community Member
Sorry, I wrote wrong the settings. Here is the settings corrected(DID isn't working):
dial-peer voice 9977 voip
huntstop
destination-pattern 914399977
fax-relay sg3-to-g3
fax rate disable
no vad
When I call to 9977 is busy. When I call from outside to fax number 914399977 is ringing in my mobile phone but never pick up.
We use ISDN
Thank you
Fernando
You may have issues with DID, do you have DID ?
Are the other CME extensions working OK ?
Can you send output of "term mon" and "debug isdn q931"?
Community Member
Hi, I will answer myself. I have got to send fax. The problem was that the Telefonica line was failed.
Thank you very much
Fernando
166
