Community Member
ATA: Not able to receive FAX
Running UCM 7.x and using MGCP Gateway.
Configured ATA and it has been registered.Able to make voice call from ATA.We can able to send a fax but not able to receive the fax.Sending end fax machine displays a message " communication error"
Please help me out!!!
Community Member
Re: ATA: Not able to receive FAX
If you call the FAX DDI and/or internal extension from a phone, does the FAX machine answer the call?
Is the ATA using SCCP/Skinny?
Community Member
Hi Rui,
Thanks for u r reply.
Yes we can able do call/receive internal extension from analog phone which is connected to ATA. (This fax machine doesn't have handset)
We can able to send the Fax but not able to receive.
Community Member
The question was not really that.
The question was, if you are able, from a Cisco IP Phone, to call the fax connected to the ATA and if the fax machine answers.
Same question, but now when you call, not from a Cisco IP Phone, but from an external phone (for example, a cell phone).
These two questions help understand if the fax machine answers or not the call. If the fax machine does not answer the call, it may be a problem with the fax machine configuration. If the fax machine answers the call, it should be a problem with the settings of the CallManager (problems with internal faxes) or VoIP Gateway (problems with external faxes).
Community Member
I am having a similar issue.
I am using H323 with CUCM6.1.2. I can call the fax from everywhere without a problem. For fax calls, Fax machines shows "receiving" then the call is dropped. Sender gets "communication error".
I have the following config on the VG:
voice service voip
allow-connections h323 to sip
fax protocol t38 ls-redundancy 2 hs-redundancy 0 fallback none
session transport udp
modem passthrough nse codec g711ulaw
On Dial-peer
Fax rate disable
Thanks in advance.
Try these things:
1. Set your fax machine send/receive speed to 14400 or 9600 bps.
2. Make sure that you have set a clock source in your voice GW:
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
