Community Member
ATA not registering, new install
Hi, I have configured the ATA just like a new phone and when I connect it nothing happens. seems like its not getting anything from the tftp? red lights blinking? Is there another step that Im missing that must be configured? Pls advise, any suggestions pls. ccm 4.2.3 es44.
thanks in advance
Community Member
Re: ATA not registering, new install
You may have problem with the ATA firmware. I have touched this also. Manuali upgrade it with newer firmware.
Other reason can be the Voice Vlan.
Regars,
Zdravko
Community Member
any ohter insights pls ??
Community Member
What is your DHCP configuration? Is it connected to a cisco switch?
Do you run TFTP from ccm?
Community Member
1. Firmware in ATA is SCCP? It can be H323, so you must to upgrade firmware to SCCP.
2. I saw some problems with registering of ATAs and there was a solution: login to web-interface of ATA and in SCCP configuration in SID0 and SID1 write "." (without quotes)
Community Member
The protocols that you can use depends on yours call agent. If you have CallManager it is better to use SCCP. You can find packet containing all the information to upgrade cisco ATA. Filename is something like ata_03_02_01_sccp_050429_a.zip. There is detailed instruction in the archive how to upgrade (sata186us.txt).
341
