02-19-2007 09:11 AM - edited 03-14-2019 08:06 PM
Hi have a shared line accross a 7912 and an ATA for some reason when I try and call a route point from either the phone or the device plugged into the ATA I get a busy tone , I have checked CSS and Device pool , region and codec and all are correct have even deleted the phone and added back in again but still get the error any idea where to look next
02-19-2007 09:35 AM
ATA for some reason when I try and call a route point from either the phone or the device plugged into the ATA I get a busy tone , I have checked CSS and Device pool , region and codec and all are correct...
This happens only with 7912's and ATAs?
Which codec you are using to dial de CTI RP?
Is a JTAPI controlled CTI RP? (Like for IPCC, AA, IVR, CUE, etc)
Which codec is supposed to be used for that CTI RP?
If you have compared the settings with a working phone and all is good, CCM trace will tell us what is happening...
Please include calling,called number and timstamp.
02-20-2007 04:50 AM
