ATA / Phone Error
Hi have a shared line accross a 7912 and an ATA for some reason when I try and call a route point from either the phone or the device plugged into the ATA I get a busy tone , I have checked CSS and Device pool , region and codec and all are correct have even deleted the phone and added back in again but still get the error any idea where to look next
Green
Re: ATA / Phone Error
ATA for some reason when I try and call a route point from either the phone or the device plugged into the ATA I get a busy tone , I have checked CSS and Device pool , region and codec and all are correct...
This happens only with 7912's and ATAs?
Which codec you are using to dial de CTI RP?
Is a JTAPI controlled CTI RP? (Like for IPCC, AA, IVR, CUE, etc)
Which codec is supposed to be used for that CTI RP?
If you have compared the settings with a working phone and all is good, CCM trace will tell us what is happening...
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
Please include calling,called number and timstamp.
Hi Thanks for you help
1) only seems to happen on q 7912 and ATA
2) Codec to dial RP = G.711
3)JTAPI Controlled RP (IPCC Express)
4) Codec should be G.711
Dialled number = 83333 calling number = 87329
Time: 09:00 am
114
