ATA question
Does the Cisco ATA support two independant lines? I know that it has two analog ports, but my impression from the Cisco product information page is that only the 188 will support two separate lines and not the 186.
-Shikamaru
Re: ATA question
I think both support two separate lines.
In ata 186 line 1 is associated to the mac address of the ata (i.e aaaabbbbcccc)
Line 2 is asscociated to a fake mac address
01aaaabbbbcc.
Re: ATA question
Alessandro is correct. You can configure two totally different lines in one ATA. Just make sure you follow his instruction:
"first mac(i.e aaaabbbbcccc)
01aaaabbbbcc. "
Re: ATA question
No, actually I think that is incorrect. The second mac address will lost its two leading zeros and an 01 is added at the end.
-Shikamaru
Re: ATA question
You are correct. The 01 is added at the end adn it drops the two 00 in the front.
Sorry.
Silver
Re: ATA question
One thing to remember with ATA
Only one port supports G711 and G729
The other port only supports G711
You can configure this, but default port 1 supports both codecs and port 2 only G711
Very annoying when you what to terminate VOIP g729 calls to port 2
Jan
115
