Community Member
ATA second port not allowing external calls to be made
The ATA 186 is not allowing the second port to allow external calling only the first port. Any ideas I saw some information about codec when using a h323 gateway
Community Member
Re: ATA second port not allowing external calls to be made
Have you enabled the 2nd port thru the web interface? The parameter is UID1, set it to 1 to enable.
http://www.cisco.com/en/US/docs/voice_ip_comm/cata/186_188/2_15/english/administration/guide/h323/h3288APE.html#wp1020164
Community Member
Yes this was set, I can make calls internally but can't call out
Hall of Fame Super Red
Hi Rohini,
The second port of an ATA can only use g.711 maybe this is the issue.
Hope this helps!
Rob
Community Member
Anyone figure this out, I'm having the exact same problem.
Community Member
Just discovered I was using G729 so that might be my issue.
150
