05-29-2008 07:36 AM - edited 03-15-2019 10:57 AM
How do you turn off the second port on an ATA? I would like it not to register with Call Manager and thus use up DLUs for unused ports or cause transient connection errors.
Thanks!
Steve
Solved! Go to Solution.
05-29-2008 07:37 AM
Steve,
To disable auto registration for any of the port set Sid 0 or Sid1 to 0 or empty. This will disable the port and not attempt a registration with CM. If you want to manually add the port in CM, put Sid0 or Sid1 as the mac-address of the appropriate port.
Sankar
PS: please remember to rate posts!
05-29-2008 07:59 AM
Go to the webpage of the ata device, for instance http://10.1.1.125. From there select the 'SCCP Paramaters' (assuming you are using sccp). Once at the parameters page, set SID1 to 0 and click apply. The event log errors will go away after this.
05-29-2008 07:37 AM
Steve,
Sankar
05-29-2008 07:59 AM
