ATA will not update loads
I have a new ATA 187 and i have it setup in a SIP config on our CME, but i cant get it to update to the newer load i have
backround
when i was first setting up the CME i set the first ATA as a SCCP but it did not work, that one did upgraded its load while under the SCCP config. i found i had to get it over to SIP in order for it to work. but now i have the second ATA up and running but it will not upgrade to the newer load. the problem i am having is the analog phone on that ATA can't access voicemail and it will not leave a voicemail on another extension. This is not a problem on the ATA that has the newest load on it. So best place to start is to get the ATA that i having issues with to the same load as the ATA that is working. i have confirmed i have all the correct software on the flash and proper "tftp-server" commands.
Some of the config:
voice register global
 mode  cme
 source-address xxx.xxx.xxx.xxx port 5060
 max-dn 15
 max-pool 15
 load ATA ATA187.9-2-3-1
 load 7821 sip78xx.10-1-1SR1-4.loads
 authenticate register
 authenticate realm all
 timezone 8
 voicemail xxxx
 tftp-path flash:
 create profile sync 0072419841051511
 ntp-server xxx.xxx.xxx.xxx mode directedbroadcast
1 ACCEPTED SOLUTION
VIP Gold
Dear,Which version of CME you
Dear,
Which version of CME you are trying ?
Try to give below command under voice register global..
load ATA-187 ATA187.9-2-3-1
Just 2 days back I have upgraded the fw on CME 10.0 for ATA 187 and I did below for that so you can compare your config with it and try.
 mode cme
 source-address 192.168.1X.XX port 5060
 max-dn 10
 max-pool 10
 authenicate register
 tftp-path flash:
 file text
 create profile sync 0620079907504524
voice register dn  1
 number 450
voice register pool  1
 id mac 34A8.4B26.088D
 type ATA-187
 number 1 dn 1
  username ata password ata
 codec g711alaw
tftp-server flash:APPATA187.9-2-3-1.img.sgn
tftp-server flash:ATA187.9-2-3-1.loads
tftp-server flash:BFSATA187.9-2-3-1.img.sgn
tftp-server flash:KNLATA187.9-2-3-1.bin.sgn
Suresh
VIP Gold
Dear,
 mode cme
 max-dn 10
 max-pool 10
 tftp-path flash:
 file text
voice register dn  1
 number 450
 type ATA-187
 number 1 dn 1
 codec g711alaw
Suresh
Like i said this is a new
Like i said this is a new install, I am running version 10.0 with IOS verison 15.4(2)T. Changing it to ATA-187 did the trick. I got the ATA to update its FW.
49
