ATA
hi, i have a problem with ATA 186
when I light on the ATA it work very well after a certain moment the calls doesn't pass anymore Im forced to reboot every time when this problem happend
had the last version , but the same problem once more
S/W Version 3.02.01(050616A)
firmware ATA030201SIP050616A.zup
thanks
1 REPLY
Silver
Re: ATA
ATA 2.14ms only works in CM3.0/3.1 environment. In CCM3.2 or later, they must use 2.15ms or 2.16ms. The workaround of the CSCdy36740 is restarting all the CMs in the cluster via the CCM serviceability page. Then they should see the correct registration status.
111
