ATA186 euro config help advice
ReadersUK
Level 2
Level 2
Hello all
i have configured an ATA186 to work with a H323 gateway, this will be used for fax. I think i have the config right but am a little concerned since last time i tried to get a fax to work with this device it failed. Can someone take a look at my config and tell me if it looks ok i am particularly interested in the settings i have on the ATA for audio and connection mode.
ata has latest h323 firmware
so settings on ATA are:
--are these ok for g711alaw?
Audio Mode 0x00150015
Connect Mode 0x90000400
my dial peer is the following
dial-peer voice 2684 voip
description fax to ata 2684
destination-pattern 2684
modem passthrough nse codec g711alaw
session target ipv4:10.230.62.220
incoming called-number 684
fax rate disable
no vad
Last time i tried this 2 years ago the fax kept missing lines of test, so i used a fxs port instead. Any help greatly appreciated.
Colin
ReadersUK
Level 2
Level 2
I thought i would answer my own question just incase someone is reading this.
the setting on ATA for europe should be
Connect Mode 0x90002400 (the 2 sets codec to g711alaw
The cisco documentation only show examples for USA.Connect Mode 0x90000400 g711ulaw
hope this helps someone
colin
