ATA186 - phone duplicate association attempt
Hi!
I have a problem with ATA186 registration (SCCP) with Cisco Call Manager Express 4.1.
Here is output of 'debug ephone messages and debug ephone register'
Oct 27 09:43.782: ephone-(42)[42] StationRegisterMessage (49/49/96) from 10.90.110.42
Oct 27 09:29:43.782: ephone-(42)[42] Register StationIdentifier DeviceName ATA001E7AC450E9
Oct 27 09:29:43.782: ephone-(42)[42] StationIdentifier Instance 1 deviceType 12
Oct 27 09:29:43.782: ephone-42[42]:stationIpAddr 10.90.110.42
Oct 27 09:29:43.782: ephone-42[42][ATA001E7AC450E9]:maxStreams 0
Oct 27 09:29:43.782: ephone-42[42][ATA001E7AC450E9]:protocol Ver 0x1
Oct 27 09:29:43.782: ephone-42[42][ATA001E7AC450E9]:phone-size 5404 dn-size 680
Oct 27 09:29:43.782: ephone-(42) Allow any Skinny Server IP address 10.90.103.1
Oct 27 09:29:43.782: ephone-42[42][ATA001E7AC450E9]:Found entry 41 for 001E7AC450E9
Oct 27 09:29:43.782: ephone-42[42][ATA001E7AC450E9]:phone duplicate association attempt on socket [42]
Oct 27 09:29:43.782: Failed SkinnyAssociatePhone for ATA001E7AC450E9 tag 42
Oct 27 09:29:43.782: Skinny register (phones=49/49/96) REJECT from IP 10.90.110.42
Oct 27 09:29:43.782: Sending message 0x48936C48 to phone 42, sock 42, tcb 0x47AA2480, SkinnyMessageID = StationRegisterRejectMessageID
Oct 27 09:30:03.695: Received message from phone 42, sock 42, tcb 0x47AA2480, SkinnyMessageID = StationAlarmMessageID
Oct 27 09:30:03.695: %IPPHONE-6-REG_ALARM: Name=ATA001E7AC450E9 Load=ATA030203SCCP051201A.zup Last=Initialized
Oct 27 09:30:03.695: Skinny StationAlarmMessage on socket [42] 10.90.110.42 ATA001E7AC450E9
Oct 27 09:30:03.695: severityInformational p1=0 [0x0] p2=0 [0x0]
Oct 27 09:30:03.695: Name=ATA001E7AC450E9 Load=ATA030203SCCP051201A.zup Last=Initialized
Oct 27 09:30:03.795: Received message from phone 42, sock 42, tcb 0x47AA2480, SkinnyMessageID = StationRegisterMessageID
Oct 27 09:30:03.795: Received StationRegisterMessage from phone ATA001E7AC450E9, sock 42, tcb 0x47AA2480
Oct 27 09:30:03.795: ephone-(42)[42] StationRegisterMessage (49/49/96) from 10.90.110.42
Oct 27 09:30:03.795: ephone-(42)[42] Register StationIdentifier DeviceName ATA001E7AC450E9
Oct 27 09:30:03.795: ephone-(42)[42] StationIdentifier Instance 1 deviceType 12
Oct 27 09:30:03.795: ephone-42[42]:stationIpAddr 10.90.110.42
Oct 27 09:30:03.795: ephone-42[42][ATA001E7AC450E9]:maxStreams 0
Oct 27 09:30:03.795: ephone-42[42][ATA001E7AC450E9]:protocol Ver 0x1
Oct 27 09:30:03.795: ephone-42[42][ATA001E7AC450E9]:phone-size 5404 dn-size 680
Oct 27 09:30:03.795: ephone-(42) Allow any Skinny Server IP address 10.90.103.1
Oct 27 09:30:03.795: ephone-42[42][ATA001E7AC450E9]:Found entry 41 for 001E7AC450E9
Oct 27 09:30:03.795: ephone-42[42][ATA001E7AC450E9]:phone duplicate association attempt on socket [42]
Oct 27 09:30:03.795: Failed SkinnyAssociatePhone for ATA001E7AC450E9 tag 42
Oct 27 09:30:03.795: Skinny register (phones=49/49/96) REJECT from IP 10.90.110.42
Oct 27 09:30:03.795: Sending message 0x48936C48 to phone 42, sock 42, tcb 0x47AA2480, SkinnyMessageID = StationRegisterRejectMessag
ATA tries to register with CCME, but CCME discards registration with reply
Oct 27 09:31:09.775: ephone-42[46][ATA001E7AC450E9]:Found entry 41 for 001E7AC450E9
Oct 27 09:31:09.775: ephone-42[46][ATA001E7AC450E9]:phone duplicate association attempt on socket [46]
Oct 27 09:31:09.775: Failed SkinnyAssociatePhone for ATA001E7AC450E9 tag 42
Here is ATA ephone configuration
ephone 42
device-security-mode none
mac-address 001E.7AC4.50E9
paging-dn 33
codec g729r8
type ata
button 1:53
And here is ephone 41 (CCME thinks that ATA already associated with id 41
ephone 41
ephone-template 1
mac-address 0019.AA68.377C
paging-dn 33
type 7912
button 1:26
I tried to remove all telephone-service configuration and aply it again. All ephones registered with different IDs but this ATA has the same problem - CCME thinks that this MAC is already associated with previous ephone ID.
Arseny
1 ACCEPTED SOLUTION
Re: ATA186 - phone duplicate association attempt
If you have previously assigned the ATA's MAC to the ephone 41, and then moved it to ephone 42, you should rebuild the configuration files for the phones (and the ATA).
if this is the case, then from global config mode issue:
telephony-service
create cnf files
reset all
! or just reset the ata and the 7912 phone
Vasil
telephony-service
create cnf files
reset all
Vasil
Dear Vasil,
Thanks for your helpful reply :)
311
