ATA186 recording feature supported or not?
I have some experience with the Active Recording feature managed by the CUCM and the built-in-bridge capability of the new phones (79X1, 79X2, 79X5, 89XX, 99XX...). It's when the CUCM setup a SIP session between the recorded phone and a compatible voip recorder (ASC, Nice, Witness Verint...), by sending duplicated RTP streams.
Recently, after upgrading some CUCM to the version 8.6(2a), I discovered that the feature report of this version lists the ATA186 as supported device for Recording: Cisco Unified Reporting > System Reports > Unified CM Phone Feature List
Here is the list:
Cisco 6911    SCCP
Cisco 6921    SCCP
Cisco 6941    SCCP
Cisco 6945    SCCP
Cisco 6961    SCCP
Cisco 7906    SCCP
Cisco 7910    SCCP
Cisco 7911    SCCP
Cisco 7921    SCCP
Cisco 7925    SCCP
Cisco 7926    SCCP
Cisco 7931    SCCP
Cisco 7937    SCCP
Cisco 7941    SCCP
Cisco 7941G-GE    SCCP
Cisco 7942    SCCP
Cisco 7945    SCCP
Cisco 7961    SCCP
Cisco 7961G-GE    SCCP
Cisco 7962    SCCP
Cisco 7965    SCCP
Cisco 7970    SCCP
Cisco 7971    SCCP
Cisco 7975    SCCP
Cisco 8941    SCCP
Cisco 8945    SCCP
Cisco ATA 186    SCCP
Cisco IP Communicator    SCCP
Cisco VGC Phone    SCCP
Cisco 6911    SIP
Cisco 6921    SIP
Cisco 6941    SIP
Cisco 6945    SIP
Cisco 6961    SIP
Cisco 7906    SIP
Cisco 7911    SIP
Cisco 7931    SIP
Cisco 7941    SIP
Cisco 7941G-GE    SIP
Cisco 7942    SIP
Cisco 7945    SIP
Cisco 7961    SIP
Cisco 7961G-GE    SIP
Cisco 7962    SIP
Cisco 7965    SIP
Cisco 7970    SIP
Cisco 7971    SIP
Cisco 7975    SIP
Cisco 8941    SIP
Cisco 8945    SIP
Cisco 8961    SIP
Cisco 9951    SIP
Cisco 9971    SIP
Cisco IP Communicator    SIP
As you can see, the ATA186 is referenced as supporting the active recording feature. You can indeed select a Recording Option and Recording Profile in the line appearance like we do for the other supported models.
But, after setting this parameter to do active recording, I am disappointed and see that it does not seem to work.
I did not find any official statement to confirm or not the recording capability of the ATA186.
Do you have more information on this? Should it work?
Any roadmap for the support on the ATA187?
Thanks for your help and feedbacks.
Yorick Petey
  • IP Telephony
Everyone's tags (3)
602
