Community Member
ATA186 resets if accessed using HTTP
when i try to access the HTTP administration pages of the device (ex. http://10.10.10.10/dev or http://10.10.10.10/AudioCfg), the ATA automatically resets.
I'm using CallManager 4.2(3)sr2b and ATA186 with SCCP firmware ATA030203SCCP051201A.
Everything else is ok (i can make calls or fax from ATA using both ports, i can ping the device using CCM and my laptop).
Thank you in advance for the help.
1 ACCEPTED SOLUTION
Community Member
Re: ATA186 resets if accessed using HTTP
I noticed something similar when access the device via its web interface through a pix/asa where the MSS window was exceeded and the packet was dropped. Don't know if it applies to your scenario but thought I would at least mention it.
Community Member
Silver
This is a hallmark example of severe SW defect. Have you checked Cisco bugtool kit or considered updating the code on the ATA - perhaps 4.5 ?
Personally I would upgrade the SW.
hth,
Ajaz
100
