ATA187 - CME - PRI - Faxing
Is there some document that describes how to setup an ATA187 connected to a fax machine to successfully send and receive faxes?  I am running CME 10, I have 187.9-2-3-1 running in the ATA.  I have dial tone, the ATA is registered with the correct DN, and faxes work - most of the time.  I have read through many articles on setting up various combinations of transcoders, T.38, pass-throughs, and codecs.  I can't seem to find a straight answer on the best way to set this up.
I get good faxes most of the time, but sometimes I only get the top or part of the top of a page.
Thanks for any suggestions in advance.
2 ACCEPTED SOLUTIONS
Re: ATA187 - CME - PRI - Faxing
Yes, in the call flow you jut described you can use a fax protocol:
PSTN---PRI---CME---SIP---ATA187
To invoke a FoIP Protocol you must have 2 IP devices, so the FoIP protocol can be invoked between the 2 ends, the first one is CME, the second is the ATA187, to know what would be the best FoIP protocol you have to consider the call flow, devices and call control protocols involve. On this paritular call flow I would use passthrough.
Try this:
voice service pots
fax rate disable
voice service voip
fax protocol none
modem             passthrough nse codec g711ulaw
voice register pool x <-- ATA Pool
no vad
codec g711ulaw
Since you have a PRI, you must ensure there are no Slips on the controller, that's terrible for fax media, take the output:
show controllers t1
sh run | sec network
sh run | sec controller
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Add the following command:
network-clock-select 1 t1 0/0/0
controller t1 0/0/0
clock source line <-- default
After adding the commands, do "clear counters" and then verify again with "show controllers t1" if the slips go away.
Jorge Armijo
Hall of Fame Super Gold
Check first "show network-clocks".
CME-CH#sh network-clocks
  Network Clock Configuration
  Priority      Clock Source    Clock State     Clock Type
    10          Backplane       GOOD            PLL
  Current Primary Clock Source
Best way to get faxing working is to have T38 end to end. Previous ATA 186 didn't support T38, but 187 are the first model to support T38. Other fax mechanism like FAX relay, or passthrough are not reliable.
How you can get T38 end to end in your scenario varies on the type of gateway you have to the PSTN. It's not the same if you have the PRI and own the ISR GW, or you have a SIP Trunk to the ITSP.
Generally speaking you want your FAX traffic not to traverse through any XCODE or any Passthorugh MTP as this normally create issues. Whether you can achieve this or not, depends on your design.
My current scenario is a PRI coming into a 2951 router running CME 10. I am using ATA187 units to connect the fax machines. Will this work T.38 end to end?
Try this:
voice service pots
fax rate disable
voice service voip
fax protocol none
no vad
codec g711ulaw
show controllers t1
Jorge Armijo
I would strongly encourage you to stay way from passthrough and look to configure T38 end to end. You can have T38 end to end setup if you own both devices. With Passthrough a single packet loss will cause the T30 session to fail. With T38 instead you can have redundancy so packets are sent multiple times and are less prone to fail, giving you a better success rate for faxing.
How would I setup the T38 with this configuration?
Bronze
I have looked at this page before but it doesn't have my particular scenario listed, and I am using CME.
Your CME is really just an H323 GW with Dial-Peers. I would recommend you try the following scenario.
Telco — PRI — GW — SIP/H323 — CUCM — SIP — Fax Server
There is no CUCM nor Fax Server on this scenario. We just have CME and ATA187.
johnivey, Can you try what I suggested? Did you check the status of the PRI as I ask?
If we find slips on the T1 faxes eill never work, no matter what protocol you use.
Jorge Armijo
I do see T1 slips.  How would I get that corrected?
Output:
T1 0/0/0 is up.
  Applique type is Channelized T1
  Cablelength is short 110
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info FPGA Rev: 08121917, FPGA Type: PRK1
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (512 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     38 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     38 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 63 15 minute intervals):
     27 Line Code Violations, 2 Path Code Violations,
     5129 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
     5129 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
     network-clock-participate wic 0
     controller T1 0/0/0
      cablelength short 110
      pri-group timeslots 1-24
controller t1 0/0/0
Jorge Armijo
I chandged the clocking as requested a couple hours ago and have 0 slips.  I have the config below.  Someone called me just a few minutes ago and said they only got the first page of a twelve page fax.
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no fax-relay sg3-to-g3
h323
  h245 caps mode restricted
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server
  asserted-id ppi
You can use the debug fax relay t30 all-level-1 command and then do the test.
Here you'll see the signaling on the t30 level. You can debug sip as well if you'd like, but the signaling would be ok as you are able to transmit 1 page successfully.
In the debug fax relay, you should check if the MPS signal is being sent by the sender, or if it's an EOP. The MPS indicates that the sender has more pages to transmit and will wait for the recepient's acknowledgement before proceeding with the next page.
Sree
johnivey
Were you able to further tshoot the issue?
Jorge Armijo
Yes, after correcting the clocking issue I have had no slip seconds.  I am waiting to see if I get anymore complaints of cut-off faxes.  I have not taken the time to do the debug test yet.  I plan to do that next week.  I will update this issue once I'm sure its resolved.  Thanks to everyone for their fine suggestions!  I will rate the posts once I confirm the issue is resolved.
John
Things seemed to have righted themselves after adjusting the clocking settings.  Thanks for all your help!
Great to hear the issue is resolved!
Thanks for rating
Jorge Armijo
644
