Bronze
ATA188 - Converting from SIP to SCCP
I have a ATA188I1-A running v3.1.1 atasip (Build 040813T) which I like to convert to ata_03_02_03_sccp_051201
How do I do this?
Thx
1 REPLY
Re: ATA188 - Converting from SIP to SCCP
Here is a set of instructions for upgrading the ATA from SIP to SCCP.
http://www.cisco.com/univercd/cc/td/doc/product/voice/ata/ataadmn/sccp3_0/sccpaapc.htm
How to upgrade an ATA:
Manually:
Download the ZIP file from the following URL:
http://cisco.com/cgi-bin/tablebuild.pl/ata186
Uncompress the files into a directory
Open the command prompt and go to the ATA files directory.
Type "sata186us -any -d1 ata_image.zup"
Go to the ATA, use the voice configuration menu, and dial: 100# ip_address_of_PC * port #,
the ATA must be previous configured with an IP address within the same PC IP address.
More details at:
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_administratio
n_guide_chapter09186a00801e0df8.html#wp1011450
Using TFTP:
Look for the file named "atadefault.txt" open it and add the TFTP IP address under the
upgrade and tftp url field, save it into the ATA directory, and once you know the file is
saved, apply the following command from command prompt : cfgfmt -tptag.dat
atadefault.txt atadefault .cfg
A new atadefault.cfg file was created, save it into the TFTP root directory, along with
the *.ZUP image file.
More details can be found here:
n_guide_chapter09186a00801e0e0c.html#wp1107755
Also make sure that when you upload the SCCP firmware into the ATA check the SCCP
Parameters and check the following parameters:
SID0: .
SID1: .
Note that there is a dot in the SID field, please change the ATA fields accordingly.
More details can be found in here:
n_guide_chapter09186a00801e0e00.html#wp1026497
I hope this helps!
Chris
646
