ATM T1 Configuration help
I could use a hand with a ATM T1 setup as I have never done one before. (Moving from a phone switch to CME 4.1)
We have an ATM t1 coming in with 10 lines for phones into our 2821. Each line has a specific telephone number linked to it. When the 1st line is busy, the Telco hunts to the next free line. When calls are outgoing, the first free line should be chosen, and the call placed.
The Secretary has the main line and answers all calls and transfers them to internal extensions. Internal extentions can also call out.
so this is what I have so far....
(line coming into a vwic2-1mft-t1/e1)
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-10
description (xxx) 341-xxxx PIC/LPIC 0233/0233
interface Serial0/0/0:0 (not sure how to setup the serial interface!)
no ip address
encapsulation hdlc
dial-peer voice 8 pots
destination-pattern 8T
progress_ind setup enable 3
progress_ind progress enable 8
port 0/0/0:0
ephone-dn  1  dual-line
number 0606 no-reg primary
label 0606
description xxx-341-0606
call-forward busy 7000
call-forward noan 7000 timeout 30
ephone  1
device-security-mode none
mac-address 0009.B7AA.216A
type 7960
button  1o1,2,3,4,5,6,7,8,9,10
Thanks in advance!!
1 REPLY
Hall of Fame Super Gold
Re: ATM T1 Configuration help
You do  not have ATM, it appears you may have T1 CAS.
Since it seems like you have no previous experience in CME telephony, I would recommend you hire a reputable consultant ot certified cisco partner for the complete setup, as if you try this by yoiurself it will be very time consuming and leading to frustration.
137
